hikerrob Posted December 27, 2011 Share Posted December 27, 2011 my 89 g.l. has an overheating problem. i was told i need to "burp" the air out of the system and im having problems doing it.i burped it out cold then started it up to open the thermostadt but every time the car gets up to operating tempature it just geysers water out of the radiator.any tips? Quote Link to comment Share on other sites More sharing options...
BratWarrior Posted December 27, 2011 Share Posted December 27, 2011 Did you turn the heater on full blast? Did you remember to put the radiator cap on:grin:? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 27, 2011 Share Posted December 27, 2011 Try filling the block via the upper radiator hose, re-connect it, and then the radiator. Perhaps drive the car and let it warm up first, then remove the cap and add coolant. Sounds like there is an air pocket in the block, and filling the radiator alone wont fill the block unless the thermostat is open, which it will have a hard time doing i there is air in the block. as stated, run the heat full hot. If the heat remains cool, there is not enough coolant. Once the radiator is full, check for a steady stream of bubbles as this would indicate a head gasket failure. how many times has the engine been overheated, or how hot did it get? What are you burping for? did you just servcie the engine, or was the coolant already low? Quote Link to comment Share on other sites More sharing options...
The FNG Posted December 28, 2011 Share Posted December 28, 2011 you may also have issues if you are not using an oem thermostat from the dealership. they are only a few bucks more and are well worth it. Quote Link to comment Share on other sites More sharing options...
somick Posted December 28, 2011 Share Posted December 28, 2011 Another way to bleed the cooling system: Park on a hill nose up with radiator cap removed. Sam Quote Link to comment Share on other sites More sharing options...
