hooziewhatsit Posted December 30, 2011 Share Posted December 30, 2011 (edited) While I have the intake off to replace a leaking intake gasket, I noticed that 90% of the mess on the top of the engine probably came from the power steering pump. Since that's the only oil I have to top off regularly, that's probably where it came from. Anyone take one of these apart to reseal it? Is it possible, or is the only option a new/rebuilt pump? The lack of easily find-able seal kits kinda points me towards replacing the pump Edit: looking at pictures online, it looks like the reservoir comes off pretty easily, and that may be where most of the mess is coming from. Edited December 30, 2011 by hooziewhatsit Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 30, 2011 Share Posted December 30, 2011 The dealer sells reseal kits for all the pumps. About $35. They are readilly available and easy to install. You will also need the front bearing which is a 6202 or 6203 IIRC. The leakage is almost always the rear cover gasket. GD Quote Link to comment Share on other sites More sharing options...
man on the moon Posted December 30, 2011 Share Posted December 30, 2011 Driving without the PS isn't too bad, if you can figure out how to route the belts (or get a shorter one) to drive the A/C, Alt, and water pump. If you can figure that out, just skip the power steering all-together--problem solved! Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted December 30, 2011 Author Share Posted December 30, 2011 Thanks GD. Found this thread with a part number while doing a google search Power steering pump repair kit Subaru # 34419AA150 list $35 http://www.ultimatesubaru.org/forum/showthread.php?t=117494#post970279 I've also found a reference to 6202-2RS used on the earlier Legacy pumps. I guess I'll compare that one at Napa to the one in the pump and see if they're the same. Quote Link to comment Share on other sites More sharing options...
l75eya Posted December 30, 2011 Share Posted December 30, 2011 And about the reservoir, yeah, it's really easy. Just undo the two hoses, and take out the two bolts and voila, resevoir is off. you can try putting some sealant around it if that's where your leak is. Or maybe the bolts are just loose:brow: haha good luck. Quote Link to comment Share on other sites More sharing options...
