CLUTCH pedal just came off?! '87 GL
49 replies to this topic
#26 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 18 January 2012 - 11:52 PM
no you should either call the dealership and add it to your order or you can get a spring of the right length and stiffness at any hardware store.
What size would it be? so i know for when i go to the hardwear store.
#27 hooziewhatsit
hooziewhatsit
    I fix old cars
  • 1,323 posts
  • Klamath Falls
Posted 19 January 2012 - 01:58 AM
Before you pull the old sheath out, take a good look at how it's routed though the engine bay, and make sure you follow the same path.
Otherwise, once it's back together, the pedal will feel nasty until you tighten the bolt at the clutch fork. Then the pedal will come up nicely. Adjust until you have ~1/2" of free play in the pedal, then tighten the lock nut. You may need to adjust the hill holder as well (at least this is a good time to check it out and adjust as needed).
:drunk:
#28 robm
robm
    Subaru Nut
  • 696 posts
  • Terrace, B.C.
Posted 19 January 2012 - 11:21 AM
The spring is a tension spring ( gets longer when stretched, starts fully coil bound). It is about 1/2" diameter, maybe 2" of coil bound windings, plus hooks at each end, maybe 1" or so each.
It hooks into the hole in the top of the fork, and then is stretched forward to another spot on the engine block or maybe the bell housing? (I can't remember, it isn't right in front of me.)
It might be time to visit a wrecker to get this part. All above dimensions are eyeball estimates from memory, no guarantees of any kind.
#29 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 19 January 2012 - 01:15 PM
I think i saw it actually. is it connected to the other side of the fork? cause there was another cable running to a spring mechanism mounted along the left front wheel well i believe. kinda low.
#30 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 4,835 posts
  • Roatán, Honduras.
Posted 19 January 2012 - 10:56 PM
That is the Hill Holder Mechanism, it has a Return Spring.
#31 AKghandi
AKghandi
    87 GL-10 2" lift 27" tires, 86 GL 2" lift 29"
  • 874 posts
  • Anchorage, Alaska
Posted 19 January 2012 - 11:07 PM
If you ever need any help pm me Ive been there already I've done just about everything you can think of and I'd like to help you avoid some head aches. Also make sure you adjust your hill holder.loose is better than tight. I did a clutch and adjusted till it was tight..took me 4 hrs to figure out why my brakes were locked up.
#32 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 20 January 2012 - 12:18 AM
alright. hopefully i get it right. man i am nervous. I still dont know what spring i should get then. can someone show me a better picture. im more of a hands on visual person.
#33 AKghandi
AKghandi
  • 874 posts
  • Anchorage, Alaska
Posted 20 January 2012 - 02:46 PM
I'm not sure how to post pics from my I touch but I'll get some video and post it when I get off work. And don't be nervous these cars are made to be worked on.
#34 AKghandi
AKghandi
  • 874 posts
  • Anchorage, Alaska
Posted 20 January 2012 - 09:38 PM
Ok I got some video of the spring
#35 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 21 January 2012 - 01:10 AM
THANK YOU SO MUCH! Alright so i think i may understand now. Where the ************ did my spring go then? Obviously i had to have one to use my clutch right? But I never saw one when i looked down at the fork? What car was that you were showing me on? Because the fork didn't look all that similar to mine.
Either way thank you for going above and beyond and showing me a video! My new cable should be coming this week and I have a buddy helping me install it i think so hopefully all goes well.
#36 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 3,770 posts
  • Mason
Posted 21 January 2012 - 02:58 AM
No, you don't need one to use the clutch, it's just there to keep the clutch fork from rattling. They often fatigue, break, and fall off of their own accord and no one notices.
#37 AKghandi
AKghandi
  • 874 posts
  • Anchorage, Alaska
Posted 21 January 2012 - 05:22 AM
No problem man And that's my 87 gl-10 turbo.. It's a beast I scare myself sometimes lol I call it the Honda stomper
#38 AKghandi
AKghandi
  • 874 posts
  • Anchorage, Alaska
Posted 21 January 2012 - 05:26 AM
But also my wagons been completely apart and there's missmatched/missing parts ( like my hillholder cable) so it may look different than yours but you get the idea.. Lol our cars look almost identical, well they will after I fix that silver fender and black hood lol
Edited by AKghandi, 21 January 2012 - 05:39 AM.
#39 okie bill
okie bill
    USMB Regular
  • PipPipPip
  • 83 posts
  • Northeast Oklahoma
Posted 21 January 2012 - 09:10 AM
86GL-10 you are my hero. Taking your car apart in the dark with a flashlight to help a board member is above and beyond. Now a question, my Brat doesn't have that spring, but the hill holder is hooked up, and has a pretty substantial looking spring. Shouldn't that be enough?
Bill
#40 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 21 January 2012 - 10:08 AM
Bill
Yeah this is how i feel. It looks like i havent had one for awhile. Maybe i can drop one it. We will see
#41 moosens
moosens
    Psychotic Subathusiast
  • 968 posts
  • Bridgeport CT
Posted 21 January 2012 - 07:42 PM
Yeah thanks old fellow moose name guy!!!!
My '78 clutch cable snapped early this AM luckily after I'd had some fun in the snow. Weird , very weird. Please don't break anything else on your car , OK??? ;)
#42 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 30 January 2012 - 12:40 AM
Stupid ************ing thmotorsports. not shipping out and giving me difficulties. Re ordered the part from a different place and should ship out tomorrow and hopefully get here by the end of the week. I just want to drive my baby again!
#43 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 08 February 2012 - 06:14 PM
alright i finally have the part! Seems easy to put on. but how do i remove the old clutch cable rubber coating piece? Does it just lift up? i dont see a bolt or anything holding it on?
Posted Image
please respond asap, trying to get this done tonight! Thanks!
#44 bigjimd
bigjimd
    USMB is life!
  • 209 posts
  • Petersburg, Va.
Posted 08 February 2012 - 06:53 PM
See on the left side of the clip where the little tab is kind of facing you? Put a straight slot screwdriver against it and tap the srewdriver and it will slide out from under the cable. It's a type of spring really. The two tabs slide in a groove and put tension against the cable and the bracket. Be carefull it doesn't go flying cause it may be hard to find. You can also grab that tang part with pliers and tap against them that way you have a grip on it. To put it back pull the cable towards you and slide the clip back on. You may neaad to tap it back in place.
#45 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 08 February 2012 - 07:07 PM
Okay sorry about that. dumb me i went back out right after I posted that and figured it out. everything is back in place. Now to figure out how much play i need int he clutch pedal. Also where in the heck did i put my j hook for my battery!?
#46 moosens
moosens
  • 968 posts
  • Bridgeport CT
Posted 09 February 2012 - 10:04 AM
On pedal side about an inch and a half before the clutch disengages. On the engine end start with about an eigth inch "strong" of play with no helper spring. Can't recall if yours has a helper like the 70's but you should be ok. I got freaked out on mine too and started calling other old schoolers but I wasn't very far off , just impatient I guess. :)
#47 Moosen
Moosen
    Subaru Fanatic!
  • 354 posts
  • Big Sky, MT
Posted 09 February 2012 - 10:42 PM
i have actual slack in the pedal where it just wiggles. I think the clutch cable is not tight enough on the engine side. gonna play with it more tomorrow. and try to pick up a return spring. cause no where online sells them -.-
#48 987687
987687
    Rally Suby!
  • Gold Subscribers
  • 3,244 posts
  • Midcoast Maine
Posted 09 February 2012 - 10:53 PM
For a return spring just go to the hardware store and get a spring that's the right length. That's what I did.
#49 bigjimd
bigjimd
    USMB is life!
  • 209 posts
  • Petersburg, Va.
Posted 10 February 2012 - 03:16 PM
X2 on the above I actually found one laying next to the dumpster at work. Brand new and fit perfect.
#50 moosens
moosens
  • 968 posts
  • Bridgeport CT
Posted 10 February 2012 - 07:16 PM
Gotta run that adjuster nut well onto the threaded end of that cable so it even looks like you're going too tight. You want to see lots of thread showing when it's new. As the clutch wears you can back it off some as needed.
