I'm hoping one of you subie geniuses could help me diagnose a wired problem with my 85 GL Brat..
Details & Symptoms:
- starts quickly, runs great & drives great for about 5 - 10 miles (varys each time)
- after reaching normal temp & driving steadily for a few miles the car starts to hesitate a bit (not much, barely noticeable)
- its typically after a stop that the real problem hits.
- takes off normally but after reaching 2/3 throttle or so, it completely loses power and seems like there's no fuel whatsoever reaching the engine, forcing me to limp over to the side of the road.
- From that point on, even in neutral, the car struggles when the accelerator is pressed and wants to die unless I floor it.. It idles flawlessly.
- problem didn't start until after the maintenance listed below....
Recent Maintenence
- Changed plugs, cap, rotor (forgot wires, doh!)
- seafoam treatment
- oil, air filter, both fuel filters (twice)
- radiator, thermostat & more....
Suspects
- carburator? I cleaned it but it seems like its getting too much air & o fuel when it's dying. Weird thing is it runs fine for a few miles while cold/at temp
- cat? The exhaust is probably the most neglected system on this vehicle. I know little about cat symptoms and have tried to search the forum but couldn't tell if it truly is the culprit..
- pcv?? I doubt it, but i popped off the t connector on the drivers side of he engine bay, and it was pretty gummed up so I shot it with some Seafoam spray and let it set before starting it back up, but the problem persisted...
ANY HELP IS APPRECIATED AS ITS SNOWING AND I WANNA PLAY, haha
Thanks!
