Legacy speedo gear ??????????
5 replies to this topic
#1 Esteban32696
Esteban32696
    USMB is life!
  • 158 posts
  • Florida
Posted 18 March 2004 - 11:01 PM
Help ! 1992 Legacy 2.2 automatic needs a new speedometer gear. How do I get the old one out of the transmission ????
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 18 March 2004 - 11:56 PM
To get to the speedo gear you need to drop the transmission and seperate the front diff housing from it. The speedo gear is driven by the front diff. I would make 100% sure that your problem isn't something else before opening that can of worms.
#3 Esteban32696
Esteban32696
    USMB is life!
  • 158 posts
  • Florida
Posted 19 March 2004 - 07:13 AM
I should have mentioned that it is a FWD car. The speedometer & cable are fine. It has to be that gear.
Is the repair for a FWD unit still the same??
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 19 March 2004 - 09:54 AM
Are you absolutely positive that is the problem?
The speedometer base is a very common point of failure for these cars. I replaced mine last summer. I was driving along and all of sudden it just died.
If you haven't pulled that base out and confirmed it is still working. I highly suggest you do that.
pic of the piece in question
http://www.main.expe...docablebase.jpg
#5 Esteban32696
Esteban32696
    USMB is life!
  • 158 posts
  • Florida
Posted 22 March 2004 - 05:23 AM
I will double check all parts . Car is FWD only. Is the gear removal from the trans still the same way??
#6 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 22 March 2004 - 09:07 AM
yup...gear removal is still the same for FWD
