ej18 to ej22 Q's???
martalien
Okay so I was entertaining the idea of taking an ej22 and dropping it into my 1996 Impreza Brighton. I hear that this is a “bolt and go swap.” I just want to make sure that I can run this with my ej18 ecu. Is there anything else that I would need to worry about or change to do make this swap a reality?
Just change intake manifolds and you can keep the wiring on it, they use different idle air controls, swapping manifolds will solve that. If your car has EGR, you will need to ej22 with egr port in the head too. If not you might get engine light from time to time.
