Engine ping while at highway speeds
4 replies to this topic
#1 heep70
heep70
    Subaru Fanatic!
  • 496 posts
  • Bonney Lake
Posted 19 March 2004 - 08:36 PM
My EA82 non-turbo pings on acceleration and while at cruising speeds. I have timed it back to 6 degrees. Added octane boost. Unplugged EGR. If I give it gas while it pings (cruising) it will go away.
Its almost like it is getting to much vacuum.
#2 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 19 March 2004 - 08:57 PM
When you say Unplugged the EGR i'm assuming that you mean you cleaned out the EGR valve. Did you also clean out the tube as well? Also check to see if your EGR solenoid is working.
#3 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 19 March 2004 - 09:47 PM
yeah I am confused about the EGR too. EGR should reduce cyl. temp and therefore pinging too.
try 5deg. my 85 gl would not take any more than 5 deg of advance.
seafoam carbon cleaner may be helpfull too.
#4 speedbump
speedbump
    USMB is life!
  • 179 posts
  • North Vancouver,Canada
Posted 19 March 2004 - 09:55 PM
try pulling back to STOCK timing (?? BTDC) remember to unplug the vacuum advance!
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,920 posts
  • Portland
Posted 19 March 2004 - 10:03 PM
Exhaust leaks can sound like pinging.... just thought I would toss that out there. Doesn't sound like that's your problem tho, since it goes away if you lay into the gas. Generally and exhaust leak will get louder when you do that.
