* * * * * 2 votes
My '83 GL: The Ski Wagon
1783 replies to this topic
#651 bratman18
bratman18
    ADIDASubarus
  • 3,843 posts
  • Jefferson, Maine
Posted 24 April 2012 - 04:12 AM
Something REALLY easy to do would be pull the motor and reseal it. These motors are so small and easy to work on, it wouldn't take much time at all.
#652 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,998 posts
  • West Des Moines, IA
Posted 24 April 2012 - 08:23 AM
Whats the process you are using to clean up the rust and then por15. Im finding im needing to do this on a couple of vehicles.
#653 TheLoyale
TheLoyale
    Safariwagon: The Legend
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 10:29 AM
I am using Wire wheel with 3000rpm HD drill, Permatex Rust Converter, High-Solids Enamel.
POR-15 is garbage and not worth the money so I've found. I can buy all of the predeceasing for less then it costs for a Qt. of POR.
#654 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 24 April 2012 - 11:09 AM
I think i might try some of that on my car and my wifes van. 05 and its rusting pretty bad already.
#655 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 11:21 AM
EA81 fires right up and runs! No leaks other then my Rad pissing like a horse.
It also redlined when I first started it, Throttle cable came off its track and got stuck half open (Whoops)
Seems to rev down slow? Is this normal for a carb motor?
#656 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 24 April 2012 - 11:34 AM
it's all in the prepwork...
#657 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 24 April 2012 - 11:55 AM
Problem is i cant take the rear suspension off to attack the rusty areas.
#658 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 03:06 PM
Why not? Mine came out. My car looked worse then yours I think?
I wonder if the motor is running off whats left in the float bowl? Maybe this is why it doesn't run very smooth. I'm gonna seafoam it once I get a new rad where I can let it run longer then 30min.
New pics later tonight.
I need to run some brake line, and wait on rear discs from Subruise (Axle nut was bustin' his balls so I heard lol)
#659 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 04:26 PM
This is how I've joined the new lines, Both hard lines almost touch in the junction, the rubber hose/clamps are just there to make sealed connection as I didn't want to use Unions and flares.
Posted Image
Rear suspension, Tank, Diff, Driveshaft all up.
Posted Image
Posted Image
Open cat. Mid pipe broke off long ago, the other ownered tried to clamp it back on, but it wasn't sealed so I found. Gonna make my own exhaust.
Posted Image
Need a new Radiator.
Posted Image
#660 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 07:03 PM
I recently had a Board memeber tell me not to long ago, that no matter what I did to my Air cleaner cover, it wouldn't look good because it was so rusty, and that I should just paint it with hammered paint.
Well, here were the results. You be the judge.
Removed:
Posted Image
Stripped:
Posted Image
Wire Wheeled:
Posted Image
Primed:
Posted Image
Painted:
Posted Image
Posted Image
Finished:
Posted Image
Posted Image
Please, Do not, tell me what I can and cannot do. This took me all of 1 hour from start to finish, I think it was worth it vs a Hammered finish. Now I just need to refinish the rest of the Air cleaner assembly.
Also, where can I get new ones of these? I would like stainless is possible.
Posted Image
Edited by TheLoyale, 24 April 2012 - 07:08 PM.
#661 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 24 April 2012 - 07:11 PM
Posted Image
Posted Image
That looks great!
Those are usually called wing nuts, that's what I'd start searching for.
#662 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 24 April 2012 - 07:12 PM
Breather top looks good. :)
I may have some better looking wingnuts for you. Have to dig around out in the garage some. But really thinking I have some in better shape/condition.
Not sure if you would find them in stainless, but it is possible....
#663 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 24 April 2012 - 07:13 PM
You probably won't find that exact style in stainless, but I know you can get stainless wing nuts. I use them on boats all the time.
#664 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 07:17 PM
Yep, was thinking stainless wingnuts as well. Although a wingnut looking wingnut would be tacky on this lol. I'll have look around and see what I can find in a M6x70 pitch?
Tom, if you can indeed find them, I would like them :) No real rust though, you know me :D
#665 TomRhere
TomRhere
  • 4,600 posts
Posted 24 April 2012 - 07:23 PM
And yeah, I'm of the same mind-set. Don't tell me "I can't" cause "I will".
One way or the other, just to prove "someone" wrong..............
(being nice guy with that, "someone" part).
#666 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 07:29 PM
:popcorn::clap:
#667 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 10:05 PM
I am not on the quest of non rotted front fenders. The bottom rears on mine are gone, the mud flap was held on with one screw. I need 1983+ EA81 fenders, I think '80-'82 have the antenna on the Driver side vs the Passenger like mine.
I have a Wanted ad going. Its a feeler for the mean time while I come up with money. I need to buy a Radiator and hoses first and some fluids to change out.
I waxed my junkyard hood today, faded Calif. paint. but it brought back some of the color lol! No shine though, ah well. Gonna repaint the entire car some day once all the Body work it done. Its gonna be a Ski car rebirth!
#668 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 24 April 2012 - 10:37 PM
We might just see some welded rocker action this weekend. I am planning on removing the passenger side door Saturday, cut out the old rockers, and weld in the new. Trying to get this done in one day so I can put the doors back on. And then repeat for the other side possibly during the week since its gonna be nice out.
Can having no Midpipe on the EA81 make it rev more gutless then the EA82? Idle seems to drop way to slow after rev. Is this something with the choke or throttle perhaps?
#669 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 25 April 2012 - 01:35 AM
they also put USSA door logos on some of the ski wagons...
http://www.indysworl...m/sale/ussa.jpg
#670 1982gl4
1982gl4
    1000+ Super USER!
  • 1,466 posts
  • Worcester, VT
Posted 25 April 2012 - 04:49 PM
Posted Image
Looks incredible. What did you use for paint (color/brand) ? I'm going to have mine all apart this weekend. It would be nice to make the bay look better at the same time!
#671 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 25 April 2012 - 05:22 PM
I used Dupli-Color Ceramic Engine Enamel in the "Pontiac Blue" Yes I know, a GM color lol. It matches fairly close and the Ceramic paint is very nice (I also used the Ceramic Gray Primer) Any parts store like O'rileys will have it.
Hope this helps you :)
#672 1982gl4
1982gl4
    1000+ Super USER!
  • 1,466 posts
  • Worcester, VT
Posted 25 April 2012 - 05:23 PM
Sweet I'll check it out! No O'rileys around here, maybe Federated will have it.
#673 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 25 April 2012 - 05:25 PM
I know PartsHut also stocks it, some stores might be limited to color choices, but sure, give it a check out!
#674 1982gl4
1982gl4
    1000+ Super USER!
  • 1,466 posts
  • Worcester, VT
Posted 25 April 2012 - 05:35 PM
We also don't have those :lol: I'll just have to look around ;)
#675 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 25 April 2012 - 05:37 PM
Napa by me has dupli-color match paint, I think I've seen that GM blue before. Thought about getting it for my valve covers.
