* * * * * 2 votes
My '83 GL: The Ski Wagon
1783 replies to this topic
#1001 TheLoyale
TheLoyale
    Safariwagon: The Legend
  • 7,079 posts
  • Waukesha, WI
Posted 27 June 2012 - 03:52 PM
Thats a good idea, I may do that later on. I just want to get this thing running again. Plus I already put the adapter on and sealed the gasket with RVT Black. I did connect that Coolant hose, we'll see if I get any leaks.
So, The only thing I didn't get with my kit, was the throttle cable bracket. Shows it in the picture, but I didn't get it. So I contacted the seller about it. You cannot use the stock cable bracket that is on the manifold, as the cable will barely reach even at WOT. The Weber bracket will work perfect once I get it!
Posted Image
Now for some questions:
Should I follow what this says? Connect the EGR and Disty Advance to the front ports of the carb?
Posted Image
I do not have the Idle Cut-Off valve (Anti-Dieseling Valve?) Do I need to get one? I also don't have the barb for the Vapor vent to canister. Mine has a gapping hole where it would go..? As you can see in this picture.
Posted Image
Where is my wire/connector for the Electronic Choke? I no longer have the old Hitachi.
Posted Image
The big line is my Supply, and small one my fingers are on is my return? Where would the return run to? The instrctions do say anything about it.
Posted Image
The Adapter!
Posted Image
Edited by TheLoyale, 27 June 2012 - 03:55 PM.
#1002 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 27 June 2012 - 04:36 PM
you can put another fitting on the weber pointed towards the front of the car that would be for the return line, or you can just leave it off. I've done it both ways... or you can reuse the feed off the hitachi. it will screw right into the weber... and it already has a return fitting on it...
you do not need the anti-diesel solenoid, and there is a hole there, but its not an open hole... if that makes sense...it would have to be drilled and tapped to fit the ADS in.
#1003 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 27 June 2012 - 05:08 PM
Huh, ok. This is getting simple lol. :clap:
#1004 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 27 June 2012 - 05:19 PM
So I found a post by JesZek, which helps with the PCV hose routing. I think this is the way I am going to go.
Posted Image
GD said that if you do not reduce the size of the fittings used, the suction will be to great, and will start sucking oil up from the heads.
But I have a decent idea what I'm gonna do.
The rest of that thread:
http://www.ultimates...ead.php?t=98693
#1005 1982gl4
1982gl4
    1000+ Super USER!
  • 1,466 posts
  • Worcester, VT
Posted 27 June 2012 - 07:22 PM
I made my own throttle cable mount using the factory one, and welding to it. I'll try to take it some photos of it at some point it's raining again now (imagine that ;) ) I'll post them up when I do!
#1006 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 27 June 2012 - 10:14 PM
If I had a flat templete and a CNC, I would make my own as well lol ;) I could probably make my own, but then again, I paid for one, and I didn't get it...
$.50 part, give it to me... :cool:
#1007 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 27 June 2012 - 10:53 PM
Does anyone have a nice chrome trim peice for the Lift gate? My chrome piece is nice, but the plastic seal is half missing and broke. And I bet when I go to remove it, I'll break studs off since they are rotted.
#1008 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 28 June 2012 - 08:15 AM
it's a nice addition, but most of the time I have just taken a flat 1/2 steel piece and cut, drilled, bent to fit, and attach it to the manifold...
don't forget the throttle return spring... I've done those lots of ways. hooked to the bottom of the air cleaner plate, hooked to the radiator, hooked to a custom bracket that was attached to the choke...
#1009 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 10:09 AM
The throttle assy was already put together, and works smooth :)
#1010 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 28 June 2012 - 11:00 AM
usually, the spring on the throttle assembly shaft is not enough to fully pull back the throttle...
#1011 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 11:56 AM
Ok, the pedal/Throttle seems to spring back like it should, I'll see how it is once its running, and ad a helper if needed.
So am I dumb, or...? Where is my original Electroic choke wire? I've looked all over the engine bay, and don't remember what used to plug into the carb. None of the open connectors I've seen look like they were for the carb, so?
#1012 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 28 June 2012 - 12:33 PM
there should have been a wiring harness for the intake. the oil pressure sender is part of it. one of the connectors off it would be the choke wire. but it's a a 2 lead connector. you just need to create a jumper wire from it to the weber choke. you need one that in +12V only when the IGN is on.
#1013 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 01:03 PM
Alright that'll help track it down! Thanks.
This is why I hate having stuff apart for months on end, you start forgetting stuff.
#1014 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 01:32 PM
So this is the only connector within reaching distance to where the original carb harness would have connected. It is a 3-spade terminal.
Here is its location:
Posted Image
I did a test, the Blue wire must be a ground as there is no voltage going to it with the key turned to "On" The 3 black/white wires have 11.98v to them with the key to ON. So does it matter which one I connect to the Webers Choke? I assume one of these wires was for the Anti-dieseling solenoid on the other carb.
Posted Image
Posted Image
Just wanted to double check before I go and do something. lol
#1015 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 01:36 PM
What I think I am going to do, to make the connection look more finished/factory is, get another Female end of this 3-spade male end, only use one spade in the casing, so it clips to the wire I want. This way it'll be plug'N play, and it'll be solid and finished.
Guess I gotta hit the JY for the female connector (I don't have one)
#1016 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 28 June 2012 - 06:23 PM
The seller I bought the kit from, is going to send me the Throttle cable bracket via Priority. He mailed it out today, and I have comfirmation. Maybe I'll get it by Saturday!
#1017 heartless
heartless
    Do YOU Subaru?
  • 3,273 posts
  • North Central Wisconsin
Posted 29 June 2012 - 07:18 AM
:clap: YAY! Progress!
I can almost hear it running now! hehe
#1018 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 29 June 2012 - 10:50 PM
lil' something I made.
Posted Image
Edited by TheLoyale, 30 June 2012 - 10:15 PM.
#1019 The Beast I Drive
The Beast I Drive
    CALL ME, (509) 391-5903
  • 2,120 posts
  • Toppenish, WA
Posted 30 June 2012 - 12:25 AM
The blue wire on the connector is for the choke. One of the black wires would be for the anti-deisel solenoid if you had one, and the other would be unused.
-Bill
#1020 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 30 June 2012 - 07:52 PM
The blue wire is for the choke eh, mine does not have any current running to it though? Only the Black wires. Guess I'll try it both ways, and see which wire I should use.
So here is the Cable Bracket which I got today! That really works nice.
Posted Image
Posted Image
I got these PCV T-connectors from an SPFI EA82. These will be used for my PCV lines, the Blue one has a restricted diameter inside, which will be perfect, as not to suck oil into the air cleaner.
Posted Image
The black one is an unrestricted T-connector.
Posted Image
I will be getting the Male spade terminals I ordered, next week. I will then buy some 22ga and make the connector for the choke!
#1021 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 01 July 2012 - 10:50 PM
I looked at a '83 GL with a Hitachi at the boneyard today, indeed, the blue wire does run to the Choke. Guess I will use that Terminal to connect to the Weber (once I get get the terminals I ordered)
Things needed to run:
1 Inline Fuel Filter (IN/OUT only, no Vent)
2 Vacuum Cap-off set
3 4ft of various vac line
4 Molded Coolant-bypass hose
5 Fuel
Still need:
1 Clutch Kit
2 Brake Pads all around
3 Metal Brake line and Unions
4 Complete Custom made Exhaust/Header
5 Driver Side Axle
#1022 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 01 July 2012 - 11:11 PM
Anyone know where I can get this style of 2-into-1 connectors? I will need one for my UEL header build to joint the two pipes.
What is this style of connector called?
Posted Image
#1023 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 02 July 2012 - 06:28 AM
Napa sells 2-1 exhaust collectors.
#1024 jboymechanic
jboymechanic
    Subaru Fanatic!
  • 421 posts
  • Waterford, WI
Posted 03 July 2012 - 08:24 AM
Get yourself an old Mopar style fuel filter.
#1025 TheLoyale
TheLoyale
  • 7,079 posts
  • Waukesha, WI
Posted 05 July 2012 - 12:07 AM
What would it take to put this on the EA81?
http://www.ebay.com/...#ht_3026wt_1282
