will a EA82 Y pipe fit a EJ22 single port engine
8 replies to this topic
#1 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,046 posts
  • Bellingham
Posted 19 February 2012 - 06:25 PM
I got a Impreza single port EJ engine need a Y pipe or wonderin if My ea82 Y pipe will fit
#2 ccrinc
ccrinc
    The Subaru Whisperer
  • 1,034 posts
  • Denver, CO
Posted 19 February 2012 - 06:27 PM
No. The EA82 is a much wider engine.
At least, I've never seen one fit.
#3 bratman18
bratman18
    ADIDASubarus
  • 3,863 posts
  • Jefferson, Maine
Posted 19 February 2012 - 07:08 PM
I wonder if the flanges would at least bolt up at all?
#4 Subruise
Subruise
    Official Party Pooper
  • 1,568 posts
  • pierce county
Posted 19 February 2012 - 09:55 PM
cut and shut? ive been dismantling a 92 legwag and its surprising how much stuff is similar to my L series stuff.
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,925 posts
  • Portland
Posted 19 February 2012 - 11:49 PM
Flanges aren't even close, nor is the width. Pipe ID is too restrictive. Not worth the effort.
I have a solution to that problem. We will be producing them soon. It's a flanged pipe that is either a slip fit or weld fit to the dual-port header by simply cutting off the dual port merge section right at the weld. These will be selling for about $65 to $75 a set and will fit in flat-rate boxes. TIG welded and water jet cut flanges.
These are made by our own sube101 (http://www.ultimates...22&postcount=36):
Posted Image
Posted Image
Posted Image
Finding single port EJ22 headers is very tricky. Subaru wants a mint for them and there are no aftermarket providers.
#6 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,046 posts
  • Bellingham
Posted 20 February 2012 - 12:38 AM
thanks guys Im trying to put the single port into my 3dr that has the dual port
#7 GeneralDisorder
GeneralDisorder
  • 21,925 posts
  • Portland
Posted 20 February 2012 - 12:43 AM
If you want a set of the header conversion pipes let me know. I was having him run off like 5 sets initially - used one a couple weeks ago. I was lucky to find a '95 engine for the forester I did last week but I may need another for a legacy I'm looking for an engine for.
#8 Gloyale
Gloyale
    It's a sickness
  • 10,835 posts
  • Corvallis, OR PNW
Posted 20 February 2012 - 01:10 PM
Who do I order a set from?
#9 GeneralDisorder
GeneralDisorder
  • 21,925 posts
  • Portland
Posted 20 February 2012 - 01:20 PM
Contact sube101 (Steven). He has these jigged up and can build you a set or a couple sets if you like. Could be about a week right now as their water jet went down for a week due to a pump failure they are playing catch up with internet orders....
The design was mine - the implementation is all sube101.
Oh and those pics are of the proto-types. I'm sure your's will be prettier. Also you have a choice of aluminized or stainless and weld or slip-fit. Slip fit uses 1-3/4" standard exhaust clamps. I would have welded the ones in the pictures but we wanted to prove the concept of the slip-fit version for people that can't weld them or don't wish to.
Edited by GeneralDisorder, 20 February 2012 - 01:25 PM.
