No EGR - pass emitions
5 replies to this topic
#1 Fozester
Fozester
    USMB Regular
  • PipPipPip
  • 34 posts
  • Sherwood, OR
Posted 19 February 2012 - 08:51 PM
So my Forester doesn't have an EGR and it won't pass emissions because its throwing a P0401 code. :banghead:
The really crapper thing is that the engine doesn't have the port for the EGR either. Do get one, it would take about $600 worth of work since it is far past my mechanical skills.
My friend at work suggested resisters but General Disorder said that probably wouldn't work.
Does anyone know any tricks so i can pass DEQ? As a last resort, I will register it to be a primary car at a place where DEQ is not required but that could come back to bite me.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,638 posts
  • Portland
Posted 19 February 2012 - 11:57 PM
Resistors won't work. You can fool the ECU into thinking the solenoid is good but that won't provide the MAP sensor pulse when the EGR opens or the O2 sensor readings the ECU is looking for to determine the EGR is working. If you do a bit of reasearch on P0400 codes you will find that people have tried plugging in working EGR solenoids (your co-worker's "resistor" trick is the same thing) and that doesn't work.
You can try swapping out to an EJ22 manual transmission ECU. That may work since your 25D was a manual to begin with.
#3 afterbang
afterbang
    USMB is life!
  • 190 posts
  • Oregon City, OR
Posted 20 February 2012 - 07:01 PM
I've been in a situation like this from swapping in a JDM N/A EJ20 engine in. It sucked. To pass DEQ, I had a shop take an EGR pipe, braze an extension on and have it connect from the valve all the way down and weld it into the exhaust manifold. This cost me like $250.00 and it ended up breaking. It did hold up for a good few years though before the engine spun a rod bearing and I had a good USDM motor installed and I passed DEQ twice with it this way. You live and you learn.
#4 GeneralDisorder
GeneralDisorder
  • 21,638 posts
  • Portland
Posted 21 February 2012 - 02:37 AM
Problem he has is that his EJ22 manifold doesn't have the EGR at all. It's the wrong casting and there's no valve or any place to put one.
Putting the EGR bung in the exhaust would be easy actually - Nissan did that with their exhaust headers. Hell I could make a weld-in bung, cut the head end off of a factory EGR pipe and weld it to a section of steel tubing and run it to the manifold. Possibly with a flex section even to keep it from breaking due to vibration.
But all this costs time and money. You wouldn't like what I would charge for this service. :drunk: As noted - $250 got a questionable job done that broke from vibration after a couple years. My version wouldn't have that problem. And the cost would be commensurately higher.
#5 idosubaru
idosubaru
  • 23,670 posts
  • East Coast
Posted 21 February 2012 - 06:45 AM
i have a non-EGR ECU, engine, and intake manifold installed in my legacy and still get the codes. seems convoluted that the issue lies in the body side wiring harness, but that's all that's left on mine?
get an intake manifold with EGR and have the EGR pipe tapped into the exhaust. that would be the easiest/cheapest solution.
#6 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 24 February 2012 - 11:37 AM
emitions tests ????? what is that no smog control here howbout a canaidain cars ecu that does not have an egr or a plate like the ea81 uses between the header and the head with a port bung on it
