Car won't shut off
8 replies to this topic
#1 kabarakh
kabarakh
    USMB Regular
  • 147 posts
  • Bellingham
Posted 21 February 2012 - 11:19 PM
Done quite a few searches using different phrases, but haven't really found any definitive answers. My car (1983 ea81 carb) won't shut off when I turn the key off, I've checked the timing on the distributor (to make sure it isn't advanced to far) and it's spot on.
Only way to shut the car off is to plug the air intake.
Am I looking at replacing the ignition column or is there something I'm missing?
Thanks!
#2 tractor pole
tractor pole
    [catch phrase here]
  • 552 posts
  • Monroe, WA
Posted 21 February 2012 - 11:25 PM
it sounds like your coil is staying energized, check for 12v at the coil when the key is off/on and see if it changes.
#3 Dj7291993
Dj7291993
    USMB is life!
  • 360 posts
  • Falcon, CO (Colo Springs)
Posted 21 February 2012 - 11:30 PM
If it's a carb, it could be dieseling. Does it do it when it's cold as well? There should be a valve to prevent that (I think it's a valve), but it could be malfunctioning.
It could also be that you ignition coil is getting power when it shouldn't be. Does anything else stay on (headlights, for example) after you turn off the key?
You may want to pull one wire off, and see if it continues to get spark with the key off.
#4 gmdagit
gmdagit
    New User
  • PipPip
  • 16 posts
  • Cottage Grove, OR
Posted 21 February 2012 - 11:49 PM
Might be the early signs of an ignition switch failing, I know some times when its freezing outside when I first try to start my car my starter will stay engaged even with the switch in the off position.
#5 man on the moon
man on the moon
    Subaru Fanatic!
  • 609 posts
  • Denver
Posted 22 February 2012 - 12:26 AM
Is it a standard transmission/can you stall it in the meanwhile?
My guess is with the switch going out OR something coming loose somewhere such as a wire causing an arc between two otherwise separate wires that effectively bypasses the ignition switch. Since the switch still turns the car ON I'm guessing it's not entirely failed, though it may be on the way.
#6 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 22 February 2012 - 12:29 AM
Its an anti-dieseling solenoid, not worth it, just have the car in gear and let the clutch up when you shut the car off (the slower you hit the release point, the less it lurches)
It was mentioned on here for an EA82 I believe that it wouldnt shut off... lemme search
#7 kabarakh
kabarakh
    USMB Regular
  • 147 posts
  • Bellingham
Posted 22 February 2012 - 12:33 AM
no, everything else turns off, fans, lights, wipers, etc. I'll check the coil tomorrow.
Appreciate all the input!
#8 kabarakh
kabarakh
    USMB Regular
  • 147 posts
  • Bellingham
Posted 22 February 2012 - 12:35 AM
Yes, I can stall it out, and I can also turn the key into the on position and bump start it. Just can't turn it off normally.
#9 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 22 February 2012 - 12:39 AM
Only thing I found was after an alternator switch... but its apparently happened before...
http://www.ultimates...read.php?t=7242
Im on my phone though, so I cant do too much more searching :-\
