Retro GL-10 TURBO build
Nico
^^ thank you guys
well i am getting ready for next spring and i really need seats for this car the factory seats do not hold you in at all :( ... ill put them in plastic in storage away so no worries lol.
so two choices
RECARO blue vintage $2500.00
OR
RECARO LS in blue $1200.00
this RECARO $350.00 seat there is only 1 :( which has the same colour !!!
LEONE inside
Edited by Turbone
LS all the way.
ya thats my pick also
I like the LS's as well. I have Recaro SE's in my GL, and absolutely love them. I'm sure with either choice you will be happy. Awesome car by the way!
nice ! with your recaros how did you do the bottoms ? my cars in stoarge so need to figure that out when i get it back.
i know the subaru seats un bolt in this car so its perfect for this, does it just lay right over and drill new holes in the recaros ?
so instead of getting those seats i went with some use old school mk2 jetta power recaros if im not mistaken.
ill get them re done in tip top shape new bolsters and bottom foam and what ever is need once apart.
the problem is finding the same fabric that subaru used, i really dont want to be re doing the hole insde of the car just becuase it wont match.
For my GL (an earlier model than yours) the front two mounts on the Recaros were perfect and just bolted in to the stock locations. The rears I had to make brackets that mounted between the seats and the factory bolt locations.
so you used the rails from subaru to the flat bottom of the recaro ? and the front holes matched up perfect to one another ?
do you have pictures or journal to view
Track this topic from the beginning, just an incredible job! keep it up!
take issue with the language translator from Google :) :)
and yet here's my album :)http://imgsrc.ru/timoha-izh/a557142.html? from date of purchase, and almost to the present day (probably half a year already unbootable photo)
and from the factory, I stood very same window visor but chrome
and finally have authorized account
Edited by Timoha
thank you !! and hello from Canada :clap: !!!
what is this ???? looks like UFO :D
:slobber:
so i found another recaro seat which this one has the head rest i want. now i just need to find one more seat to match the head rest.
also found a spare set of track wheels for my leone, VOLK RAY's STi GC8. i'm going to paint a set of these some funky bright colour.
and still cant find fabric for my recaro jetta mk2 seats yet :mad:
To you thanks! and Hello from Russia from all owners of Subaru leone!
It not the UFO is a chandelier :) so at us in Russia call, salon illumination green and usual lamps at an open door or forcibly and there still is the fan, it has two modes weak and strong, it probably is more similar to the filter :)
p.s. by the way on other disks looks smartly :)
p.s2. other translator found, he more best than Google much more think
p.s3. also can you can help to take the measurements of a back nave of xt6?
Why You just not install seats from impreza Sti?
Here's mine, replaced from 2004 STI:
Looks and feel pretty good, but maybe it needs to stay a little lower (for me high seats is a habit now, after almost 2 years of use) :).
  • 3 weeks later...
i will find out but my car is in storage right now for the measurments.
WOW very nice ! :clap: i have all ways used the STi seat in all my other build's.. this time i want something diffrent and lighter
so i got one of my set of STi TE37 VOLK sand blasted ready to get painted a colour that i have not picked yet, i'm thinking a nice glossy jet black but will see soon.
also some oem subaru parts have come in, new XT6 front control arms. i have to problem's that i need fixing with these. 1 is the bushing end rubs in my subframe arm, 2 i dont have camber in the front.
ill be adding something like these to the arms so i gain in both aspects
also i have ordered another rear diff support mount, which i will be adding a new bushing in the middle to help with the flexing in the rear R180 diff. if your driving behind my car, as i shift in a gear ! you can see the diff flex, which all most looks like its going to fall out lol.
For the fabric of your new seats, perhaps you could have the old cloth carefully removed from the stock seats and re-installed on the new ones? I wouldn't know if there is enough material on the old seats to cover the new ones but it is worth looking into.
-Bill
ya i was so thinking the same idea but these recaros will only be used when i'm at the track doing some lapping days, that way the seat can hold me in around corners.
also i have found some fabrics that will be good for what its worth, ill just put the original seats away for a rainy day.
so my rims got done ready to roll again, thanks to NVauto for installing the tire's again :D. So the other gold set i have will be face sanded and re painted gold.
one more thing that i need to add to them which is in the mail on its way.
  • 1 month later...
how much was the diff support bushing? if you dont mind me asking.
I'm not sure how this car can get any better but I'm sure curious to see what happens next. :headbang:
i think the diff thing was 80 ill check for you
lots more to come, i want 400whp on the dyno dynamics
I'm curious to hear how you like the Potenza RE-11s, compared to the Advan AD08, as it looks like you have some time on those too. I've been pretty stoked with my AD08 but it's almost time for another set.
i really like both tires, but there is something about the re-11 that made me feel like i could push the car harder in corners and they where very quiet tires felt smooth.
there should be the new re-11a coming out that ill be getting
so i found another set of JDM Subaru FHI 4 pot 2 pot, i had them sand blasted and now powder coated red. i got new oem seals to rebuild them & some GODSPEED Brakes stainless steel pistons to rebuild them with, also need to paint the letter's on the calipers white and find a sticker for the rear. ill most likely sell the other gray set that are on the leone or use them for the next build that's going on all ready
also got some nice STi Magnesium Valve Rocker Cover Set coming in, very excited for these all ways wanted them.
also its all most time to order my new turbo the S300SX FMW so i can make my goal of 400whp on a dyno dynamics dyno.
Can you send me a limb off of your money tree so I can plant it here in Colorado.  Dang you get the nice stuff!
Magnesium rocker covers?!  :blink:
hehe buy low sell high i guess
i wanted them for so long the rocker covers and i think this build should have them the most.
so i just hand painted one subaru decal on the 4 pot, came out all right i think. now i need to find the stickers for the rear 2 pot some where.
looks ok with the black GC8 volks i did in black.
WOW fastest shipping in the world took place ! my GODSPEED BRAKES stainless steel brake caliper pistons got here :eek: i just placed the order like on Tuesday and there from the UK !!
time for me to get to work
think i found my 17" wheels ?????? by my calculator calculations it looks like they will fit. that means i have to get a set of STi Brembos up front.
if they don't fit guess ill have to put them for sale :(
S202 STi RAY'S VOLK FORGED 5x100 17x7.5JJ ET 53
SUBARU TECNICA INTERNATIONAL STi
FORGED MADE IN JAPAN
