Retro GL-10 TURBO build
Nico
So I have two questions.
1. How did you get the mustache bushings out of the mustache?
2. Where are you in Hamilton? I am ironically in Burlington right now and odd as it sounds I would love to see this?
1. I pressed them out in a press that I have at my house, did all my bushings new oem.
2. Sent you a pm
Simply magnificent Nico! Thanks for showing us just what can be done with these great old cars!
:) thanks !.. Ya it's turning out to be really good for how old styling it has glad you like how it looks so far
:burnout: Nico, you win. You have the coolest Subaru period.
Lol thanks man :) ... It's cool that I found such a perfect car to work with or else it would have never happend
that steering wheel looks good, I am waiting on my hub adapter it is in route from Germany:headbang:
nice you got it !! let me know what you do to make the horn work. you have to take the clock spring off just the center section.
ill put a pic up of how to make the horn work right i have a idea.
cool, I have been thinking about that too. I will put up some pics after I get it.
is that wheel a 350mm?
the hub should be here in about 2 weeks! I am still looking for that wheel that I have... haven't used it for 10+ years and I have moved 5 times... ugh!
nice progress btw!
Edited by tractor pole
nice progress btw!
i dont really know what size the wheel is sorry. but i did figure out how to make the horn work perfect.
the inner ring is the horn ring so what i did was make like a big coil spring with some not to thick steel wire. ill have to show you hard for me to explain. wire is all most like coat hanger wind it up like a spring and it works perfect.
AWIC pipes and other bits which is moving along nice and smooth. couple back order stuff which is killing me ! summer is all most done.
Didn't get back to you Nico, it was a busy Friday. But I am headed back to Hamilton/Burlington in middle August so possibly then I could bug ya to see it.
On your mustache bushings were they hard to get out? I got the new bushings but haven't looked at the mustache yet. I am betting a 32 year old Brat will have rusted bushings. Any tips on that - sorry to take away from your thread with my questions.
its ok no worries when you come back up let me know when your hear and will meet up.
my bushings where very simple and used and abused thats for sure. maybe sand blast them first then try to press them out ! if you cant do it bring it up and ill pop them out and new in for you no worries.
clutch line made fluid and bled, ready to go
this picture is just crazy all in its self !!! it makes me not even want to drive this car and put it away for another 26years !!!!
Franz Diebold wiring Diebold Autosport ! its just so beautiful i am speechless !! thank you Franz.
:slobber: WOW!
Um, bringing the mustache from Colorado, US might be a problem, lol. Thanks for the offer though.
i see ya that would be a trip with that thing LOL
shifter plate is all done bolts in.
my LC1 is ready to auto tune and get me going till Franz comes and really dials it in
and the diff is mounted in ready to go
the bracket my father made extra strong so the diff dont end up down the street LOL
my brake lines all made up this is the rear it has 2 sections that i got made.
front brake lines done
and the diff fluid is ready to be add
injector dynamics 1000cc
install all goods
Franz amazing harness. swapped the avcs from passenger side to drivers side, then all in one plug... + add boost controller plug, oil pressure, fuel pressure.
Vi-Pec V88, and my mod case mount to make it sit in the factory spot like oem that i did.
fits like a glove
fits right where subaru put the original oem 1986
  • 2 weeks later...
here we have the shifter mount, its a mix of 1986 sway bar bushing rubber and good old fashioned father steal bending and welding. ! lol its so simple but yet feels so right when shifting.
then we had to fix the rear sway bar mount points, thanks to the great Canadian salt we use for our roads, it destroyed the tabs to hold my mounts.
way it should look with a tab, but not a hole in the middle !
so once again my father came up with these, we made these tabs which is nice and thick to last 50years. once you weld them over paint and done.
oem 86 XT6 20MM sway bar
1986 GL-10 Turbo Filter looks way better made then the new style.
so we are pretty much done under the hood, add battery, couple water lines for cooler and done.
that thing beside the brake master need to be in the car for my heater  control's to work vac system. so i used a new style fuel filter holder  and bolted it up and it works perfect nice and clean.
and while i was board i cut out the spare cap i have for the Extra S  gear oil i had, and stuck it on the top of the cap for the water cooler.
as of now we are pretty much ready to start it up but !! tomorrow my  drive shaft shop shaft will be in. then im just waiting on my water  coolers for my intercoolers.
Edited by Nico
I can almost smell the tire smoke...:popcorn:
LOL LOL LOL LOL ************ i have a feeling you are so right ! lets ee if this Subaru AWD system is ready to handle this for sure hahha.
Sooooo much win with this...
hehe :) !!
well it came in !!
Drive Shaft Shop one piece aluminum prop shaft.
man o man is this thing so light weight. so they told me its 4" inch shorter then a STi shaft. which means even more less weight & 4" inch shorter wheel base.
so now just AWIC coolers on back order some time this week or next & weld up my exhaust + muffler + tip & my twin scroll dump tubes.
then we start her up ! next week we drive it.
  • Like 1
Do you plan on adding any extra chassis bracing? How do you feel the stock chassis will hold up to that kind of power?
next year a will make some bracing, its to late and at this point i want to break it in and get it dialed in.
Again, this thing is awesome. Thanks for sharing this.
:headbang:
thank you no worries, its all most done cant wait.
wow almost done!
can we get a closer look at your tranny mount to give pre 87.5 model ppl some ej tranny swap inspiration?
also what was the part number on that momo steering wheel hub?
Kaz
yep all ready test driving it, just need water coolers and i can driver her fast lol... ill get you some pics of what i did.
well Franz helped set the car up making sure everything was up and working checking over all system a go !! no joke.. the internet is a amazing think, plugged her up via
internet next i know he is turning on fans, fuel pump, injectors and so on !
VIDEO no exhaust
VIDEO with exhaust
exhaust
dump pipes
Edited by Nico
