Another RWD option
10 replies to this topic
#1 Numbchux
Numbchux
    EJ conversion addict
  • 6,831 posts
  • Saginaw, MN
Posted 06 March 2012 - 04:21 PM
I'm sure it'll be a few years before these start showing up used, but theoretically a person could walk into a Subaru or Scion dealer in a few months and order a bellhousing much like what Bill is making (although I'm sure it's much more expensive). Check out these pics of the BRZ running gear
www.ft86club.com/forums/showthread.php?t=3981
Now, I know that the fb20 and fa20 engines (BRZ gets the fa, IIRC) use the same bolt pattern as the 8-bolt EJs, the question will be, what transmission is that? likely a Toyota unit, like the rear diff.
#2 LeoneTurbo
LeoneTurbo
    EJ engine expert
  • 341 posts
  • Arnhem (The Netherlands)
Posted 07 March 2012 - 09:39 AM
Starter is in the wrong position for EJ-use...
#3 carfreak85
carfreak85
    Temple of Fuji
  • 5,247 posts
  • Cascadia
Posted 07 March 2012 - 11:03 AM
I was reading an article on motoiq.com (awesome site for car/engineering nerds) and I think the trans and rear diff are from the lexus IS series, which have pretty good aftermarket support.
#4 shortysayhi
shortysayhi
    Subaru Fanatic!
  • 411 posts
  • Conifer (outside denver)
Posted 07 March 2012 - 11:59 AM
Diid anyone notice that the oil filter is on the Top of the engine...?
#5 Numbchux
Numbchux
  • 6,831 posts
  • Saginaw, MN
Posted 07 March 2012 - 01:16 PM
look again. you can see the familiar opening on the left side for the starter. I'm assuming this setup uses a different flywheel with more offset, so the starter doesn't protrude into the engine bellhousing.
yep, the new FA and FB series engines both have the filter on top. They also use timing chains and asymmetrical rods like the EZ36DR.
and yes, I've heard the transmission and rear diff are Lexus units as well.
#6 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,101 posts
  • NH
Posted 08 March 2012 - 09:51 PM
http://www.ft86club....=1&d=1330656888
Looks like you'd have to notch the normal EJ bellhousing mating surface on the passenger side to fit the starter. EJ's don't have a bulge on both sides.
#7 Gloyale
Gloyale
    It's a sickness
  • 10,649 posts
  • Corvallis, OR PNW
Posted 10 March 2012 - 12:52 PM
The passenger side "ear" would just stick out.
There would be a bit of a cavity down into the clutch area, but that could be capped off......or left open.....wouldn't matter.
Might interfere with a turbo though :rolleyes:
****edit.
Now I get it. he meant notch the adpatrer to use that trans with an EJ engine..........Yeah.....maybe would have to notch.
on a side note.....I wonder if that Rear end set up will make it's way to newer subarus. Might open up some stronger diff and axle options.
Edited by Gloyale, 11 March 2012 - 10:18 PM.
#8 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 12 March 2012 - 03:57 AM
Those photos are amazing, I love it. I can't wait to drive one. I also can't wait to drive the new 2012 Impreza especially with the CVT mounted to the 2.0 engine. I think it will be decent. Finally in Corolla territory for MPG.
:L the comments on the thread about the boxer being hard to work on. His loss.
#9 AKghandi
AKghandi
    87 GL-10
  • 1,197 posts
  • Somewhere, Someplace
Posted 13 March 2012 - 12:22 AM
All of that needs to go into my wagon.. I would drift it competitively.. Every day.
Any clues as to what the ratio is on that massive rear diff? I smell air locker options...
#10 mellow65
mellow65
    Subaru, my drug of choice
  • 1,086 posts
  • Portland
Posted 21 March 2012 - 10:43 AM
From the reading I have done its going to have a rear end common to the nonturbo supra and is300 stuff, which was a IRS 8", which was the same size ring and pinion as the truck stuff. So gears oh plenty, and lockers and spools and lsds. Oh my.
But that's all from reading, it's going to take someone to crack it open and see for sure.
#11 Numbchux
Numbchux
  • 6,831 posts
  • Saginaw, MN
Posted 21 March 2012 - 12:54 PM
^Yep, that's what it looks like to me. Toyota 8". And, it looks like that rear crossmember would swap right into a multilink AWD car (BEs/GEs).
AND, with stuff like this going on, I imagine it won't be long before someone cracks one open and offers some aftermarket for it.
