1999 Ej22
6 replies to this topic
#1 kanurys
kanurys
    High Altitude GL
  • 707 posts
  • Durango, CO
Posted 16 March 2012 - 12:47 AM
There were two EJ22's available in 1999 Imprezas. I think it was a change - mid year. What do you guys know about the differences. I have one that has a plastic oil separator plate but I thought they changed that in phase II engines. What is this one?
I did a valve adjustment on it and basic tuneup. It's roller rocker and very similar intake setup to my 1998 legacy outback 2.5 hydro lifter engine, if that any clue.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 16 March 2012 - 01:06 AM
Do the plug wires go through the valve covers? If so its a phase-II. If not its a phase-I.
98 2.5 is solid lifter. Bucket/shim.
#3 kanurys
kanurys
    High Altitude GL
  • 707 posts
  • Durango, CO
Posted 16 March 2012 - 01:39 AM
Thanks GD. Yeah they do go though the covers. I replaced all the seals, etc, when I did the valve adjustment. I know my 98 is bucket/shim. When that dies, instead of fixing the heads I might use the block and build a dual port frankenmotor for it. Will the 2.2 dual port heads fit the dohc intake manifold and exhaust? Just want to know what to look for when the time comes.
On topic: It looks like the Phase II 2.2 on my engine stand has a plastic oil separator cover.
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 16 March 2012 - 02:44 AM
The old 2.2 has the spark plug wire enter thru the head itself, the newer one goes thru the valve cover first.
#5 kanurys
kanurys
    High Altitude GL
  • 707 posts
  • Durango, CO
Posted 16 March 2012 - 09:44 AM
Thanks. If you ever make it down to Durango, give me a heads-up and I'll show you my soobs or we can go wheeling or something.
#6 idosubaru
idosubaru
  • 24,010 posts
  • East Coast
Posted 16 March 2012 - 03:17 PM
99 EJ22's are single port exhaust, not dual port. are you talking about your 99 engine or do you have a 95 you haven't mentioned yet (which are dual port exhaust)
i think i can still answer your question: the *only* intake manifold that fits on a DOHC EJ25 is the DOHC EJ25 intake manifold. there are no EJ22 intake manifolds that will bolt up to the EJ25 DOHC heads. does that help?
99 Phase II EJ22's are single port exhausts so you'll need the exhaust manifolds. the intakes are not compatible with earlier Phase I EJ25's or EJ22's.
#7 kanurys
kanurys
    High Altitude GL
  • 707 posts
  • Durango, CO
Posted 16 March 2012 - 04:33 PM
Well that settles that. Thanks Gary.
