SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 Do you have Brown intiorior? No complete interior....I have some pieces though. What are you needing? Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 Does anyone have rear differential bushing mounts or have any advice for me? No bushings... Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 hey Todd.. ready for that gen 1 brat hood release cable... also do you have two center caps for later wagon style white rims?? Please email me at tbag1331@yahoo.com for shipping details.. Thanks, Tommy.. Will do...out of town currently. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 I mighty have shocks for BRAT. Pm me I have rear shocks if you still need them. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 I could use a pair of solid interior door latch surrounds for 78 brat. Any color. Hard to find in good condition. I have no more of these. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 1, 2016 Author Share Posted June 1, 2016 Do you happen to have rear shocks for first gen BRAT or the clock to the right of the radio? I have a few working clocks remaining...and shocks 2 Quote Link to comment Share on other sites More sharing options...
biffanyus Posted June 1, 2016 Share Posted June 1, 2016 (edited) Ok great.. dont need the center caps now found some.. Just the hood release cable when your ready..Thanks, Tommy.. ps side front marker light rubber gasket not the whole assembly with lens but just the rubber gasket part. If you want to sell with lens I'm fine with that too... Edited June 4, 2016 by biffanyus Quote Link to comment Share on other sites More sharing options...
Borderguy Posted June 2, 2016 Share Posted June 2, 2016 I have a few working clocks remaining...and shocks Sending PM Quote Link to comment Share on other sites More sharing options...
Wiclipse95 Posted June 8, 2016 Share Posted June 8, 2016 Hi Todd, I'm I the market for 1 flying saucer hub cap. Also I was hoping you may be able to help me locate the fuel pump relay for a EA71 (1979 Brat). Let me know, thank you Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 9, 2016 Author Share Posted June 9, 2016 Hi Todd, I'm I the market for 1 flying saucer hub cap. Also I was hoping you may be able to help me locate the fuel pump relay for a EA71 (1979 Brat). Let me know, thank you No saucer hubcaps..... Fuel pump in the 79 BRAT draws power through the voltage regulator and ONLY when the alternator is putting out current. Often the VR is bad if you have no power to the fuel pump. No relay is in that circuit. Quote Link to comment Share on other sites More sharing options...
Wiclipse95 Posted June 10, 2016 Share Posted June 10, 2016 I replaced the Voltage regulator last week, the fuel pump and filter the week before. It seems like I'm not getting power at the pump though. I have read a few threads that suggested there is a second fuel filter close to the tank, I have been unable to locate it thus far. When I add fuel to the carbs throat it fire right up so I know it's getting spark. Is there something in the tank it self that could be clogged? Thanks for your help. I'm also interested in the brown plaid seats if you have some available. I'm new to the site and neglected to follow the thread when I asked a few weeks ago. Thanks again Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 10, 2016 Author Share Posted June 10, 2016 No brown plaid seat covers left. Use a voltage meter and check the power at the fuel pump. Do it quick when you have it running. The alternator needs to be putting out power. If you have power and your fuel pump in new, it's safe to assume that is not the problem. Also...remember that the fuel pump is not a motor that runs all the time...it is a pulse pump and it will "click" vs purr/or run like an electric motor. If no power, try "temporarily" running a power line from the + battery terminal to the lead on the fuel pump. Also, that pump "grounds" via the mounts and nuts. Check the ground. You can try to put a big syringe on the fuel line from the tank at the fuel pump...... with some fuel in it and do a "push/pull" with the syringe. That can sometimes clear a restriction. There is no additional filter at the tank. Quote Link to comment Share on other sites More sharing options...
Wiclipse95 Posted June 11, 2016 Share Posted June 11, 2016 Thank you for your insite, how about a carpet pemplate? Quote Link to comment Share on other sites More sharing options...
GL_Giles Posted October 14, 2016 Share Posted October 14, 2016 Hi Todd, do you have any more of the clocks that go to the right of the radio? Looking for one of those and actually looking for a radio as well. I know the original was embedded, but for some reason someone took it out and slammed an aftermarket tape deck there at some point. Thanks! Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 16, 2016 Author Share Posted October 16, 2016 PMd you GL Quote Link to comment Share on other sites More sharing options...
biffanyus Posted October 26, 2016 Share Posted October 26, 2016 hey Todd. You happen to have gen 1 brat front side maker inner rubber/ plasitc piece that holds the bulb and surrounds the lens.. just need one.. don't need the lens unless you want to sell it as a whole.. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 26, 2016 Author Share Posted October 26, 2016 I sure don't Tommy. Quote Link to comment Share on other sites More sharing options...
The Wagoneer Posted November 8, 2016 Share Posted November 8, 2016 You don't happen to have a driver side rear swingarm do you? Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted November 8, 2016 Author Share Posted November 8, 2016 I only have an NOS 2WD version. Quote Link to comment Share on other sites More sharing options...
The Wagoneer Posted November 13, 2016 Share Posted November 13, 2016 Ok thanks Todd. I'll keep looking. Quote Link to comment Share on other sites More sharing options...
biffanyus Posted December 14, 2016 Share Posted December 14, 2016 still have gen 1 brat rear shocks??? PM me how much plus shipping to Florida Quote Link to comment Share on other sites More sharing options...
