Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Windshield Wiper Help
#1
Posted 23 March 2004 - 01:20 PM
Ever since then my driver's side wiper wont run (it kinda rises an inch or two, then drops again, while the passenger side runs fine), and if you grab it from the outside, you can pretty much move it anywhere across the windshield you want (instead of it being locked.)
So my question is first, does this mean I have to replace the wiper motor, or is there an easier way to fix this (or is it even more complex than just fixing the motor), and is it something I could do myself, or something that I better let the Subaru dealer fix? Thanks.
#2
Posted 23 March 2004 - 01:22 PM
#3
Posted 23 March 2004 - 01:45 PM
I looks like the wiper has broken or stripped the mooring to his shaft.
Remove the faulty wiper from the shaft and have a look: it's maybe only a question of replacing and retightening, maybe a bushing needs to be replaced.
#4
Posted 23 March 2004 - 02:08 PM
How would I get the wiper arm off? Just yank it off or is there some special thing I have to do to get them off. Sorry for being car-stupid lol.
#5
Posted 23 March 2004 - 02:15 PM
This said, i remember someone on the board having a similar problem a while back.
This person will possibly chime in and give you the rest of the help you need.
Good luck!
#6
Posted 23 March 2004 - 02:18 PM
#7
Posted 23 March 2004 - 02:22 PM
#8
Posted 23 March 2004 - 02:32 PM
#9
Posted 23 March 2004 - 05:09 PM
Last year, I discovered that my driver's side was a bit loose. It hadn't slipped, but would have in the near future. It was just a case of tightening the nut down. I believe there is a plastice cap over the nut as frag mentioned, but I'm not 100% sure without looking.
If you have run your wipers like this with the one slipping, you 'may' have smoothed off the knurling, or gummed it up a bit. Still, it may be fine. Just clean up the contact surfaces and tighten things up. See what happens. No cost to trying.
Commuter
#10
Posted 23 March 2004 - 05:56 PM
#11
Posted 23 March 2004 - 06:15 PM
#12
Posted 23 March 2004 - 06:32 PM
I have the wiper arm in my hand. I was able to unscrew the nut easily with my hand (if that means anything). Also, when I freely moved the wiper across the windshield with my hand, the nut moved along with the wiper (again if that means anything). The center part did not move when i moved the wiper. I didn't try running the wipers to see how much that piece moved, however.
Now, I am trying to tell if this thing is worn or not. on the wide part where it connects, its very smooth, so it doesn't look like this really part was supposed to be rough in the first place.
where it is narrower, I can barely make out some grooves, and I'm gussing this is where the problem is. I'm not sure how big these grooves are supposed to be, but they sure dont look that big. If these are almost completely worn down...I am guessing that means I need to buy a new arm, correct?
#13
Posted 23 March 2004 - 08:54 PM
Also, try operating the wipers with both wiper arms removed. It won't do any harm, and you should be able to see what moves and what doesn't.
Good luck.
#14
Posted 23 March 2004 - 09:40 PM
The shaft is knurled (I believe). The arm hole is not. The knurling is just a slight grooving, nothing more. The arm is made of a softer metal than the shaft. It will take on a slight 'impression' from the knurled shaft. This impression is probably gone from the slippage. But it doesn't mean that anything is necessarily damaged. Reattach the wiper arm to the shaft. Tighten the nut (but don't overdo it). Test it by pulling on it slightly (trying to turn it that is). If it slips, then reposition and tighten a bit more. Put the plastic cap back on and you are done.
Commuter
#15
Posted 26 March 2004 - 03:23 PM
~Howard
#16
Posted 26 March 2004 - 04:32 PM
I'm missing the plastic cap on one side of my wipers. Anyone know where to get another one ?
Umm, the car next to you at the mall?
Just kidding, maybe subaruparts.com or a local junkyard.
#17
Posted 27 March 2004 - 08:08 AM
#18
Posted 27 March 2004 - 10:54 AM
On at least two occasions this winter i started the car with the wiper switch still on and the wiper blades frozen to the the windshield.
Each time the motor, after a brief attempt to move the wipers, sort of tripped itself shut without any damage to the wipers mechanism.
Is this built in or am I just lucky?
One of my friend who owns a Mazda broke something in the mechanism each time the same thing happened to him.
#19
Posted 28 March 2004 - 10:16 AM
http://forums.nasioc...25&pagenumber=1
Kevin
#20
Posted 28 March 2004 - 09:38 PM
Kevin
