I have a 95 legacy LS.
I have replaced the seals on the front crank and front cam seals.
Is there a seal or an "o" ring that can/should be replaced on the rear of the cams?
How difficult is it to change?
Suggestions.
Reason, there seems to be an oil leak that may be coming from that area. Not it is not the valve cover or valve cover bolt seals/ they have been replaced.
Thanks for the information
gerald in NC
Assuming you have an EJ22, on the right (passenger) side head there is a rear cam cover that is sealed with an o-ring. Two bolts hold the cover in place. Very easy to change.
EDIT: I didn't explain it very well the first time.
On the left side, there's an O-ring between the cylinder head and the camshaft support (the part which takes up space between the head and the timing cover, and holds the cam sensor). The O-ring is exact same part as on the right side.
