forsinapu Posted March 24, 2004 Share Posted March 24, 2004 I have a 91' Legacy Turbo that i'm replacing the wheel bearings on, the problem is everything has come loose and is ready to have the bearing pressed in except I can't get the ABS sensor off. I took the bolt out that attaches it to the backing plate but it won't budge. Anyone have any ideas?? Thanks Quote Link to comment Share on other sites More sharing options...
Setright Posted March 24, 2004 Share Posted March 24, 2004 Lots of penetrating oil (WD-40, RP-7, that sort of thing), wait for at least twenty minutes and tap it gently with a softface hammer. Quote Link to comment Share on other sites More sharing options...
Guest jclay Posted March 24, 2004 Share Posted March 24, 2004 i just did the same operation to replace my abs sensor, if you don't Need to do this, i would not recomend it. once you remove the bolt, it won't budge- attached to the back of that plate is a cylinder that houses the sensor, that cylinder fits very snugly into a hole/tunnel/channel (whatever) my replacement came from a junkyard, so i had the luxury of removing the entire strut/wheel assembly to get a better view. anyway, if you can get the right view/angle on the thing you will notivce that there is a small gap between the plate that had the bolt in it and the rest of the assembly. i inserted a screwdriver into the gap, pounded it in with the BFH, and the cylinder started to slide out, then i carefully pryed it out all the way. to install onto my car, i lined the cylinder up with the hole, and used a rubber mallet to pound it back in. then put the bolt back in. it is a Very tight fit. anyway, dispite the blood sweat and swearing, once i did this, and hooked up the lead, and my abs works fine again. if you have any other questions, you can email me direct at jclay@hotmail.com i'll be happy to help Quote Link to comment Share on other sites More sharing options...
