Clutch step question
6 replies to this topic
#1 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,267 posts
  • Everett, WA, USA
Posted 24 March 2004 - 04:45 PM
Ok so i'm using an EA-81 flywheel with all other EA-82 parts into a 5spd Dual range, my question is what is the step depth, between where the bolts mount and where the clutch surface rides. cause if its too big, it'll slip like i have now, but if its too thin, i'll have it stick, and being in GM central no one knows anything about it. anyone know the spec?
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,184 posts
  • Central Iowa
Posted 24 March 2004 - 04:49 PM
your ea81 flywheel should be turned to ea82 D/R specs.....
a decent machine shop should have the specs......
#3 NoahDL88
NoahDL88
  • 4,267 posts
  • Everett, WA, USA
Posted 24 March 2004 - 11:50 PM
are the specs that much different than the Ea-81? cause they don't seem to have many specs on hand
does anyone know what they are?
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Posted 25 March 2004 - 12:23 AM
I don't think its necessary to turn the flywheel when using an ea82 clutch disc as long as u use the ea81 pressure plate and ea82 throwout bearing it should work fine from what I was understanding..
I really need to make sure this is true before I slap all of mine together but Jerry (Bratsrus1) didn't do anything except have his flywheel turned as far as I understood.
#5 NoahDL88
NoahDL88
  • 4,267 posts
  • Everett, WA, USA
Posted 25 March 2004 - 07:44 AM
I'm using an Ea-82 pressure plate, i thought that would be ok, i guess we'll see tomorrow.
#6 greggbrat
greggbrat
    Eat, Live, Breath Subaru
  • 263 posts
  • Denver Colorado
Posted 27 March 2004 - 02:20 AM
Did you do the tranny swap? And what is the correct answer to the parts used? Which pressure plate? Throw out bearing? Clutch? Flywheel?
Any other surprises in the swap?
#7 NoahDL88
NoahDL88
  • 4,267 posts
  • Everett, WA, USA
Posted 27 March 2004 - 12:12 PM
I posted another thread, but the quick and dirty is that you use the flywheel and pressureplate from the same engine, ie if its an EA-81 use the ea-81 flywheel and pressure plate, if your installing an EA-82 tranny, like the 5 spd dual range use the EA-82 clutch and throw out bearing, the pilot bearings are the same for both flywheels.
