I just got a 1990 automatic legacy wagon. It has 107k on it now and had a new transmission put in at 80k. So, when I drive rpms go up to 3000 then it finally jerks into gear. This happens going into 2nd and 3rd, not as bad going into 4th. 2nd and 3rd feels like the cars gonna split in two. Where should I start?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1990 legacy automatic jerks from gear to gear
Started by
freshpoppie
, Apr 23 2012 10:42 AM
4 replies to this topic
#1
Posted 23 April 2012 - 10:42 AM
#2
Posted 23 April 2012 - 10:47 AM
check line preshure. if tourque converter was inproperly installed will damage trans my bett is that did it start after trans was installed ?
#3
Posted 23 April 2012 - 11:11 AM
Not sure when it started I just bought the car. Thanks, I will check that out when I get home today.
#4
Posted 23 April 2012 - 01:46 PM
Does the engine feel shaky or sluggish? Does it feel like it bogs down at higher rpms? This could be a misfire or power issue causing you to apply more throttle than normal, and will cause the transmission to shift harder.
Check the fluid condition and level as well. Is it red? Dark? Black? Smell like burnt toast?
The 4EAT trans is not known for being a particularly smooth shifting transmission, but there are additives that can help, and clean fluid always makes a difference.
#5
Posted 24 April 2012 - 09:28 AM
have a turbo legacy came in yesterday no reverse and no low gear put it in low just like brakes are on has welded the low reverse clutch pack but it is very noticable what gear is the problem one on your car ?
