MY quest for ground clearance. pics!
AKghandi
Aha! How about this?:brow: its 2x2 and just about 1/8th thick, the thickness concerns me but im not going to do any serious offroading..i think it came from a stop sign ...not sure how it got there though.
Edited by AKghandi
yeah the only problem there is i have no idea where to go for steel tubing. ive been to lowes and homedepot neither of them have it..here in anchorage theres not alot of places that sell stuff like that. im going to go to a few more places tomorrow or find something that will work like a 4wheeler ramp or an old trailer. something 2x2 and atleast 1/8 thick
I am not sure if they sell to the public...
http://www.alaskasteel.com/contact.htm
Google search:popcorn:
I get stuff like that from a machine shop. My front lift blocks are 2x2 3/16" (pretty sure 3/16", not 1/4").
It's not something you want to underbuild though. Failing suspension is bad and dangerous. No reason to try to save a few bucks when the consequence is crashing your car due to failed suspension.
You would be surprised how poorly a lift kit could be made, and still work just fine. I seen stacks of washers used :eek:
3/16" would be the optimal choice if you are buying it, if you are getting scrap for free, take what you can get as long as it'll work.
Indeed it will probably cost about the same, cause once you start buying bolts, nuts and washers, you already into $30. Plus whatever the steel runs you, then the time it takes to weld up and drill.
I think this was a good route! One Eye is a good guy!
Also, you don't want the rears to be actually 2" from hole to hole.
Since you aren't changing the pivot point, if you move the strut mount 2" down, you are actually pushing the wheel (6 inches further down the arm) down about 3 1/2" I see alot of these 2" lifts where the rear sticks up in the air too far, and the rear axles are maxed out.
When I do this type of lift, I make the rear straps with about 1-1/4" from hole to hole......which yeilds about 2" of actual lift.
