box coolant by radiator's blew out from coolant.
15 replies to this topic
#1 Suba_GL_87
Suba_GL_87
    Eat, Live, Breath Subaru
  • 413 posts
  • Your mom home
Posted 13 May 2012 - 11:56 PM
96' EJ25 DOCH outback wagon-
my girlfriend and i drove up hill from mountain pass.
we notice temp. gauge going climb up to overheat and saw smoking under the hood.
we pull over and saw the coolant box's by the radiator were broiling even inside the radiator broiling too. Seem coolant not even through into engine.
so, i was thought it's water pump broke and new replaced timing belt kits too, do am i right? what you think it's problem solving.
thanks.
#2 Mike104
Mike104
    Subaru Fanatic!
  • 731 posts
  • N KY
Posted 14 May 2012 - 07:22 AM
Head gaskets
#3 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 14 May 2012 - 07:37 AM
Yep.........head gaskets........your 96 has a reputation of blowing head gaskets. Do a search here on this website for "head gaskets," to read lots about it.
#4 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Head gaskets
Classic head gaskets.
You just noticed the most telling symptom.
Most important thing is to not keep doing this. If you stop overheating it just HG replacement may do. Keep driving it and a 2.2 swap is the cure.
#5 Suba_GL_87
Suba_GL_87
  • 413 posts
  • Your mom home
Posted 14 May 2012 - 01:22 PM
but my muffler had no coolant smoking?
#6 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,022 posts
  • East Coast
Posted 14 May 2012 - 01:49 PM
headgaskets. you can verify that we're right by either listening to us or going to the auto parts store and getting a kit that tests for exhaust gases in the coolant.
that is not a failure mode of this engine, so you won't see that.
not all engines have the same failed headgasket symptoms. as a matter of fact no EJ25 from 1996-2010 will exhibit oil/water mixing or coolant out the exhaust, which are what some people typically look for. they don't fail that way.
headgaskets - they are pushing exhaust gases into the coolant - heating it and causing it to hydrolock, not ciculate, overheat, and boil.
#7 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 14 May 2012 - 02:47 PM
There is a tool that percolates the gasses from the top of the radiator through a blue fluid. If it turns bright green, the cooling system is contaminated with combustion gasses. That's the first step in confirming your headgaskets are gone.
#8 Suba_GL_87
Suba_GL_87
  • 413 posts
  • Your mom home
Posted 15 May 2012 - 02:34 PM
got you.
i already tear down but timing belt DOHC...hard to removed sprocket.
so, seem need buy the large pliers jaw for removed camshaft's sprocket before out the camshaft?
#9 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 15 May 2012 - 02:42 PM
No, you will break or chip the cam pulleys. Take the valve cover off, there's a spot on each cam you can grab it with a wrench, I think a 1 1/16 fits? It's been a while.
#10 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 15 May 2012 - 03:39 PM
yeah and those cam pulleys are not cheap
#11 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 16 May 2012 - 05:31 AM
If you need cam pulleys let me know.
I have a set of 4 I pulled for another member already pulled that he ended up not needing.
Usually folks just need the right side. I put them in a kit I call "the dreamers kit" or "I'm feeling lucky kit" often for folks that had a timing belt break or idler fail, valves collide, and they think it's just the cam pulleys that broke during the crash.
It includes both R side cam pulleys, a used timing belt, and used idler of your choice. Enough to make you realize jus thos screwed you are and that the engine needs to come apart. Then I have heads for when you realize what the real fix is. Again it's usually just the R side.
They will need the cam sprockets at some point anyways.
I seem to sell about 4 of these sets per year. Infact I'm almost out of them.
#12 Suba_GL_87
Suba_GL_87
  • 413 posts
  • Your mom home
Posted 16 May 2012 - 12:19 PM
how is smart are you!
Really, i use large clamp lock on the belt make this stay before remove camshaft's sprocket.
#13 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 16 May 2012 - 05:42 PM
I had a friend do that and he paid $100 for a new sprocket from the dealer because he needed the car running that weekend. The sprokets are fragile and the bolts holding them to the cam are usually brutally tight.
#14 Suba_GL_87
Suba_GL_87
  • 413 posts
  • Your mom home
Posted 16 May 2012 - 09:41 PM
thats good for when i can install camshaft's sprocket...i need to know what torque on it?
#15 Suba_GL_87
Suba_GL_87
  • 413 posts
  • Your mom home
Posted 17 May 2012 - 12:50 PM
i notice EJ25 said need new heads bolts?! after install head gasket.
#16 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 19 May 2012 - 09:55 AM
You don't need new head bolt as they are not of the stretch kind.
