That would be my sister's brand new 2008 Outback Sport in the background
Realizing I owned 3 cars and a motorcycle ('87 RX, '89 XT6, '85 GL turbo, and a '08 Yamaha R6) now while living in an apartment, I had to sell it a week after I bought it. Luckily, it went to a good home, Turbone's home. After a good polish, transmission swap and suspension conversion to standard springs and struts, he took it to WCSS10 and took Best XT/XT6.
6 months later, I had sold off the XT6, the '85 GL and sold off the drivetrain from the RX, I needed a car to drive during the winter, Turbone loaned it to me and I fell in love. I ended up getting it back shortly after from him (thanks Rob!) and started to tweak it.
Started by swapping my Enkei RPF1 rims onto it. Here she is with Rob's ebony collection.
Then she went in for tint. Sporting 18% just for reference.
I then swapped in some KYB GR2s in the front with the addition of some EBay coil over sleeves for an Impreza. Also now had tinted tail lights and front marker lights done with VHT Nightshade. Then she went to WCSS11 where she won Best XT/XT6. Again, with Rob's black RX.
After that, I continued with regular maintanence as modifying my daily driver was not only a dumb idea but also expensive. Then right before WCSS12, she was involved in a hit and run incident while I was at my parents house, enjoying Father's day. I come home to this...
I stopped driving it after it started leaking a quart of oil in less then 500 miles. I also needed to do other work to it with the suspension so I made due. After a few shop changes, I found myself working for All Wheel Drive Auto, an independent Subaru repair shop. Lucky me:drunk:
Then I decided it was time to get moving on getting it ready to take to WCSS12. I did a full engine reseal with the last OEM engine gasket set in the US, along with new timing belts, rollers and tensioners. I even replaced the automatic tensioner for the driver side belt (thanks ShawnW!) with a new OEM one. A new clutch kit went in, water pump, serpentine belt, timing belt covers, and oil pressure sending unit I replaced the 3.90 converted clutch LSD to a 3.90 viscous LSD from a Legacy. Also did a full fluid change on it (transmission, rear differential, brake fluid with ATE blue, and Motul engine oil) the day we were supposed to leave for WCSS13, and she started having issues. Since it was a fairly long drive to the event, I decided to not go and risk having more issues on the trip.
I let her sit for a few weeks before I mustered up some will to go see what was going on. Finally had a Check Engine light illuminate and pulled a Coolant Temp Sensor code. Pulled the connector and it was pretty green so I cut it off and modified one to work. One thing I am lucky for, is my roommate who is also my coworker so we carpool to work in his '90 Toyota 4Runner so my car sits in the garage.
Anyways, since it sits most of the time, I've been doing a lot more stuff in regards to the suspension and brakes. Let's just say I will do a full update on it after WCSS14 this summer:headbang:
All of my pictures of the vehicle are on my Webshots location
http://community.web...user/caboobaroo
