Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
P0106, MAP Sensor Re-visit
#1
Posted 25 May 2012 - 10:26 AM
It feels like the car is running out of fuel. I give it some throttle and the engine just falls flat on its face, barely has enough power to get out of its own way. Then after a few seconds it picks up and carries on as if nothing were wrong, shift gears and the fun starts all over again. It does this more when cold, once it's warmed up it kinda goes away, but not completely. Never stalls, doesn't misfire, it just doesn't want to accelerate at low Rpm. When it gets wound up to about 4000 rpm it seems to go away.
I've swapped MAF and Knock sensors with spares that I have tested and know are good. No change. Checked fuel pressure and get steady 28psi at idle, picks up to almost 40 when driving and never fluctuates, even when the engine is struggling.
Checking various readings with my scanner, the only thing that stands out is the MAP, which seems happy to sit at 0.5 inhg constantly. I have two spare MAP sensors which I have swapped at other times in the past to try to cure the MAP code (never fixed it) and will swap one of them in today and see what the reading says with another sensor. I've also tested and swapped the PSS solenoid, which again made no difference.
I will also hook up a vacuum gauge later today and see what, if anything, that tells me.
#2
Posted 26 May 2012 - 10:40 PM
Anyway, I did get somewhat of a break today, tried to start the car after swapping the steering rack and it wouldn't run. CEL came on immediately, so I whipped out the scanner, got a P0100 MAF sensor code. Seemed strange for it to die, but I swapped it with the one I took off two days ago and still no change. Found a broken wire in the harness, one that I had soldered together several years ago while troubleshooting, of all things, a MAF sensor problem. Repaired the solder joint and the problem went away. Haven't driven the car yet because of an issue with the extended steering shaft from the lift not quite fitting properly. It seems the input shaft on the "new" rack is about 1/8" longer than the old one, and it was causing the u joints to bind. So when I get that dremeled out tomorrow I can drive it and see if the power loss issue has been solved.
#3
Posted 27 May 2012 - 07:12 PM
#4
Posted 19 June 2012 - 10:30 PM
So then I went chasing after broken wires poor grounds and low voltage from the ECU, none of which I found. It was hot so I gave up. Might have a go at checking voltage and signal while I wiggle the wire harness on the ECU tomorrow morning before it hits 90. Posed to have 100+ heat index tomorrow so if it doesn't happen before 10 it wont happen at all.
I have 5.1V reference at the sensor. Approx. 0.9 V on pin 2 at idle, but it doesn't change with RPM increase. I looked for a while but couldn't find any info on sensor output compared to vacuum.
Edited by Fairtax4me, 19 June 2012 - 10:33 PM.
#5
Posted 20 June 2012 - 04:01 AM
#6
Posted 20 June 2012 - 04:42 AM
what a mess.
#7
Posted 20 June 2012 - 11:50 AM
Using a scan tool, watch the MAP sensor value with the key on, engine off. Compare the BARO reading with the MAP reading. They should be roughly equal. The voltage for the MAP sensor should read approx. 4.5 volts. Now start the engine and look for a significant drop in the MAP sensor voltage indicating the MAP sensor is working.
The MAP sensor on these cars serves double duty as both Baro and MAP sensor. A solenoid inline with vacuum before the sensor switches the pressure source when the ECU tells it to. Only have a MAP value on the scanner.
I hadn't though about checking voltage output from the sensor with the engine off. That should tell me that the sensor is responding to vacuum. Thanks for that idea!
Yes checked continuity between the sensor and ECU. ECU isn't hard to get to though, just pull the carpet back and 4 screws to remove the cover plate.
#8
Posted 20 June 2012 - 03:51 PM
It's down to two things. Either the ECU is bad, or I have three bad MAP sensors.
#9
Posted 23 October 2012 - 12:46 PM
Basically I left this alone until just a few days ago when we had time to play around with some stuff in Electrical class. So I grabbed my two spare MAP sensors and put them on the test trainer in class.
5v and ground hooked up, I got 3.8v from both sensors on the signal pin with no vacuum. Hooked up a vacuum pump and at 19" I got 1.6 v from both sensors. Finally found some info in the FSM about the voltage to expect from the sensor and this falls not exactly in spec but close enough for me. Put a meter the one in the car and tested 5v on pin 3, no back voltage on ground (good ground), and 1.2v on signal pin w/no vacuum. Hooked up vacuum pump got 1.2v.
Now is where this gets interesting... Tested the same sensor out of the car, 5v and ground hooked up... 3.8v on the signal pin. 1.6v at 19" Hg.
Back to the car, pull the ECU connector off, recheck wires, continuity good, no shorts. Decide to pull the sockets out of the harness connector at the sensor. Hook up power and ground pins, but NOT the signal pin... Key on, 3.8v on the signal pin. Key off, plug in the signal pin, key on again, now have 1.2v signal.
Pull the ECU connector off, pull the signal wire out, key on 3.8v at the sensor, 3.8v at the ECU end with the signal wire UNHOOKED.
???????!!!1
Pretty much what I had assumed before but this finally confirmed it. The ECU is bad.
#10
Posted 31 October 2012 - 06:14 PM
wow, what a crazy mess, would have never guessed that.Pretty much what I had assumed before but this finally confirmed it. The ECU is bad.
i have a 1996 Legacy Lsi EJ25 ECU if you want it.
so - is it probably the shorted wire that fried the ECU?
#11
Posted 31 October 2012 - 09:24 PM
The ground for the MAP is (according to the FSM ECU I/O) shared by several other sensors and since none of them are acting strange I fail to see how that can be the problem.
Got a solid 5V at the sensor, reference is good.
The only thing I can think, and this is based on schematics for a Toyota ECU so it may not be the same for the Subaru, is that there is a resistor that bridges the reference and signal traces in the ECU (a "pull-up" resistor if I understand correctly). The resistor would have to be open internally, providing no pull-up reference to the signal trace, which would tell the ECU that the signal voltage is out of spec. Or, what I think is more likely, there is a poor solder joint or connection, or corrosion (some form of high resistance) inside the ECU on the MAP signal trace. Unless there's something I'm missing.
I'd like to open it up to see if I can see anything obvious, but don't want to take the ECU apart without having a known working spare on hand.
#12
Posted 08 December 2012 - 02:21 AM
First improvement: I get a MAP reading on the scanner! It seems low at 10" at idle, but its there!
Second improvement: Made two stops on the way home and no CEL, no DTCs pending. Two ignition cycles is all it took before to trip the CEL.
Power loss issue may be resolved, a few more drives will confirm but I won't be too disappointed if it isn't, as long as the CEL stays away.
Fuel mileage has been kinds low lately, hoping that now the ECU has a proper input from the MAP it'll lean out a bit. Again here, not gonna be too disappointed if it doesn't. Kinda figure this thing needs an O2 sensor by now anyway.
It's only been like 4 years? since this issue first popped up. I should organize some of my experiments throughout this story into a write-up.
