oil pan bolt question
10 replies to this topic
#1 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 27 March 2004 - 09:35 AM
ok i stripped the 17mm bolt on my oil pan , it is still on the car and not leaking , what would be the best way to get it off? what other bolts would fit ? it is really tight , would any auto parts store have 1 ? thanks :banghead:
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 27 March 2004 - 10:40 AM
jim, when we were in WV, we bought an oil pan drain plug for some 2 bucks, and it came with a nylon gasket for the drain plug.
#3 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 27 March 2004 - 10:52 AM
what auto parts store ? advance auto ? now to get the old one off ,i have plenty of oil pan bolt gaskets , thanks
#4 subusolo2nut
subusolo2nut
    USMB is life!
  • 175 posts
  • Eagle Point
Posted 27 March 2004 - 01:21 PM
If you stripped the threads out--you might need to get a "oversize" plug--these cut new, slightly larger threads--Napa stores carry them--of course, the oil pan is a piece of cake to R&R--just slap a new (to you) one on & be done with it--- :)
#5 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 27 March 2004 - 01:27 PM
ok, thanks
#6 GeneralDisorder
GeneralDisorder
  • 22,049 posts
  • Portland
Posted 27 March 2004 - 03:41 PM
pipe wrench
#7 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 27 March 2004 - 05:34 PM
i went and got a new bolt for the oil pan, i still can not get the old one off , any suggestions ? besides replacing the oil pan , would a impact work ?
#8 Meeky Moose
Meeky Moose
    Subaru Master
  • 2,343 posts
  • Grants Pass
Posted 27 March 2004 - 07:35 PM
did the same on my wagon.. i gae up after claping vice grips on with channel locks so hard that the teeth dug into the plug, then just stripped 1/4" off the plug.. i had to siphon the oil out of the check tube to change it.. gonna just replace my oil pan..
on another note a shop said they'd get the plug out and replace it for about $60 but i have oil pans galore just sittin around.. and it leaks too soo..
#9 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 27 March 2004 - 07:47 PM
Autozone has drain plugs last I checked.
#10 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 27 March 2004 - 10:18 PM
i have a new drain plug , i'll check with a local shop and see what he can do , he ows he a favor anyways , then i guess a different oil pan , which i do not have ,
#11 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 27 March 2004 - 10:57 PM
http://www.fumotovalve.com
i have one of these on my wagon and it's worth the money. You will want to tickle the skid plate to use a drain hose more effectively.
