97 outback
110 replies to this topic
#76 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 01 February 2014 - 05:59 PM
^man I would love to have a outback that clean! I have a huge rust issue on the passenger side rear door area where that stupid black plastic part is.. I hope I can shape some metal to wield on that area.
Anyways I'm going to start building this MSD coil kit, I just need to run to home depot to get some longer bolts, need to still order valve cover gaskets and everything so far is going good.
#77 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 01 February 2014 - 07:02 PM
Thanks, that outback had no rust anywhere which was awesome, what is the advantage of the msd coil kit?
#78 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 04 February 2014 - 06:59 PM
They say a bigger spark 36Kv vs the 20 or so with the Subaru.
#79 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 04 February 2014 - 08:13 PM
Thats interesting, I wonder if they make one for the EJ22? I'll have to look into that. Thanks!
#80 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 05 February 2014 - 12:01 PM
Car wont start now.
#81 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 05 February 2014 - 01:40 PM
Won't start with the new coil? If you put the OE one back on will it start up?
#82 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 05 February 2014 - 01:41 PM
Turns out it was the starter.. I replaced the contacts but not the plunger about two years ago.
#83 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 06 February 2014 - 11:47 AM
Nice troubleshooting! Whats next for the wagon?
#84 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 06 February 2014 - 03:33 PM
Most likely JDM taillights and modding them for LED's I need for the spring to come so I can replace the hatch, hood and body repair.
#85 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 07 February 2014 - 11:35 AM
Ordered this today
http://www.ebay.com/...984.m1497.l2649
I really needed just the plunger but I will just replace everything again, it's super easy to get to the starter anyways.
#86 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 08 February 2014 - 06:14 PM
too tired today to do the timing, still trying to check where that coolant leak is.. I can only think it's a hose or i forgot to put a hose clamp on near where the IAC is, it only leaks when the system is full, Changed the oil yesterday.
Any tips on getting to the knock sensor? LOL last time I had a very hard time getting the bolt onto the sensor.. I remember dropping it and having a hard time trying to fish it out, the way the 25D's intake manifold is makes it harder..
I was thinking maybe some glue on the end of the bolt head so I can at least thread the bolt in.
#87 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 08 February 2014 - 07:54 PM
What helped me do the knock sensor is taping the edge of the bolt with electrical tape into the socket so it would hold it, then as soon as its tightened you can easily pull the socket up.
#88 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 08 February 2014 - 09:04 PM
Doh forgot about that! yeah that would work!
Also I'm going to try and get as much teardown as I can of the old block.. it's been riding around in my wagon for almost 3 weeks now.
#89 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 08 February 2014 - 09:25 PM
Haha that's hilarious! Sounds like a typical subaru guy, it's rather terrifying if you were to wreck and that thing came flying at or around your face!
#90 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 08 February 2014 - 09:28 PM
lol funny you should say that I had to come to a hard stop the other day and that was my first thought.. just glad my tool bag was zipped up at the time.
I'm going to try using the bar to get the wrist pins out for the pistons
#91 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 09 February 2014 - 05:47 PM
LOL you can tell I'm a newbie at this.. I did not know the pins for the pistons were so visible after you take the circlips off.. I expected them to look a bit different.. lol
Anyways I took some video of that #2 piston on the Ej25d block, it must be at least 5 mm of play on the crankshaft.. took the oil pan off and it looked like glitter :P
I will keep Piston #1 as a keepsake
Anyone know what size the bolts are that are where the water jackets are? I thought it would be 14 mm 12 point but it's smaller.. maybe 10?
Also redid the timing on my hybrid motor and holy crap does it pick up after 3K.. It feels better in that range than the Ej25d IMHO, it spins up faster it just feels so good! I found my coolant leak which did not take too long to find as soon as I started the car up I guess the screw band was not tight enough so it would leak right on the block and the headers and made a nice smoke cloud.
Videos in a few since I need to head out.
#92 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 09 February 2014 - 09:31 PM
Video of the crankshaft and the crazy play!
So it seems low oil so far killed it, wont really know until it gets split but all the others had no play.
Edited by 1-3-2-4, 09 February 2014 - 09:32 PM.
#93 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 11 February 2014 - 10:25 PM
Almost forgot about the starter kit coming in the mail today, I will get around to it tomorrow.
#94 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 13 February 2014 - 07:52 PM
Well? Today is yesterdays tomorrow, did you finish up that starter? I had full intentions of installing a hitch on my car after work today, yet I arrived and had not the slightest amount of motivation. Perhaps tomorrow. But only if this baby stays in thy wife a little longer.
#95 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 14 February 2014 - 05:02 AM
Got hit with another 7 inches of snow
#96 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 14 February 2014 - 09:17 AM
Damn, where do you live Mike? I forget if I asked before.
#97 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 14 February 2014 - 10:07 AM
Connecticut we have at least 24 inches total so far. . I have to do it today because I stalled on a hill and was unable to start it again.. because yesterday was so light in traffic I just parked in the middle of a heavy road hit the starter and that was it
#98 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 14 February 2014 - 12:28 PM
Found a clean enough spot and took the starter out and replaced everything, now just time to put it back in.
#99 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 14 February 2014 - 11:57 PM
I love the good ol starter smack! Hopefully you got that thing in and it was successful. I always hated getting to that bottom nut. Im gonna hook up a trailer wiring harness tomorrow, should be about 60 which is nice.
#100 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 16 February 2014 - 06:15 AM
ha 60 is nice!
Here is the starter repair
I took the pistons out of the Ej25, turns out I had a long drill bit.. like 15 inches long and it was 1/4" pins came out real easy.
Now I had to order online a 12mm 12 pt thin wall socket because no stores here had one that was thin enough to get to the bolts where the water jackets are.
