TheSubaruJunkie Posted March 28, 2004 Share Posted March 28, 2004 1992 Legacy Sport Sedan. The sunroof will only operate part of the time. If the car is shut off, sometimes when you start it the switches on the sunroof control will actually work. The roof will open, close, or tilt open. But if I open it, or have it at tilt, and drive for a while, the switch will stop working. None of the buttons will do anything. Before, if I slammed the inner cover shut then it would make the switches work again... long enough to shut the sunroof but now its not working any longer. Anyone else have problems like this before? -Brian Quote Link to comment Share on other sites More sharing options...
gbhrps Posted March 28, 2004 Share Posted March 28, 2004 Back a few years ago my wife's Toyota Cressida did much the same thing. The solution was a new sunroof computer, not cheap as I recall. Before you go that route, I would suspect that you might have a bad switch. If you can pop the switch out from its bezel and disconnect it, I would see if you couldn't spray in some electrical contact cleaner into it and cycle the switch several times to clean its contacts. Give it a few minutes for the cleaner to evaporate before reinstalling it and seeing if that will do the trick. Good Luck. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 28, 2004 Author Share Posted March 28, 2004 I dont think its the switch because if one works... they all work. If one doesnt work, none of them will. -Brian Quote Link to comment Share on other sites More sharing options...
baccaruda Posted March 28, 2004 Share Posted March 28, 2004 you should check the switch anyway in case it's a relay or power supply problem. check the fuse and the sunroof motor too.. Quote Link to comment Share on other sites More sharing options...
CJK440 Posted March 28, 2004 Share Posted March 28, 2004 Mine is acting up too. It decided to stop working now. When I press the button to open it I hear a click like a relay clicking up in the roof near the drivers sun visor. Doesn't budge though. Quote Link to comment Share on other sites More sharing options...
lefty42303 Posted March 28, 2004 Share Posted March 28, 2004 I have the same symptoms with my '90 Legacy. I can hear a relay clicking in the roof somewhere but no sunroof action. Wile watching the ammeter I see no deflection indicating that the motor isn't getting any power or motor is acting intermittent. Don't wanna pull headliner out cause I think I'll tear it all up. Let me know what you find. Thanks, Lefty42303 Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted March 28, 2004 Share Posted March 28, 2004 My (for a week) 91 Legacy did that... then Andrew bought it and tried changing the switch and some other stuff. Not sure if he ever got to the bottom of it, but it acted up too. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 28, 2004 Author Share Posted March 28, 2004 Mine doesnt make a sound when i hit the buttons. I'll inspect all the wiring sooner or later. -Brian Quote Link to comment Share on other sites More sharing options...
dashton Posted May 3, 2005 Share Posted May 3, 2005 I have the same problem with my '90 legacy wagon. Anybody out there experienced this or found a way to fix it? The sunroof will work perfectly sometimes, and then not at all others. I'm assuming there's a short or bad connection somewhere, but I'd like to get some advice before I tear it apart. Thanks. Dave Quote Link to comment Share on other sites More sharing options...
