I can't program it. After all the initial instructions to get the car into the programming mode, the horn should blow once to indicate the program mode is active and then you press each button one at a time. When done remove the ignition key and the horn will blow three times to indicate the program mode is ended. Trouble is not with the remote, but with the car since it never blows the horn to indicate you're in the programming mode. Anyone have a similar issue and how did you fix it?
http://www.ultimates...&pictureid=3679
Edited by edrach, 15 June 2012 - 05:21 PM.
