Parking brake doesn't work after rear brake/rotor change
11 replies to this topic
#1 ibroad
ibroad
    USMB Regular
  • PipPipPip
  • 69 posts
  • SC, 2002 Outback 2.5L
Posted 02 July 2012 - 06:12 PM
I had my rear brake/rotors changed recently on my '02 Outback and after I got it back from the place my damn park brake doesn't work anymore!
I usually park on an incline at work and when I engaged the parking brake the car just kept rolling back.
I brought it back into them and they said they fixed it, but it still does it!
What the hell did they do?
#2 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,902 posts
  • Near Cortland NY
Posted 02 July 2012 - 06:52 PM
Could be they didn't adjust them enough, does the lever show some resistance when you yank it up?
How many clicks?
Could be the shoes or the drum are contaminated, you might try driving slowly, holding the button down, and pulling the lever up to where it has some resistance to scuff the shoes and drum a bit.
#3 Rooster2
Rooster2
    Subaru Master
  • 4,687 posts
  • Indianapolis
Posted 02 July 2012 - 07:10 PM
Pretty sure the hand brake is cable activated. Not positive on a Subie, but that is how I have seen it on other cars. Look to see that the cable is attached to each brake, and to the bottom of the hand brake mechanism under the car. Might be a disconnected cable.
#4 coolskaterkid
coolskaterkid
    USMB Regular
  • 145 posts
  • south lake tahoe
Posted 02 July 2012 - 11:20 PM
I had the same issue, it ended up being the parking brakes shoes, the ones in side the drum needed to be adjusted. So i did till the drum just barley slid on, and problems fixed.
#5 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,941 posts
  • Charlottesburg, VA
Posted 03 July 2012 - 12:20 AM
Park brake shoes need to be adjusted. It can be done with a brake spoon (curved blade type tool used to turn the adjuster without removing the rotor). Or adjust the shoes outward a little at a time while removing/replacing the rotor several times until you get a nice tight fit.
#6 ibroad
ibroad
    USMB Regular
  • PipPipPip
  • 69 posts
Posted 03 July 2012 - 07:59 AM
Is this something they should have done when I had the brakes/rotors replaced?
#7 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,902 posts
  • Near Cortland NY
Posted 03 July 2012 - 08:17 AM
Most certainly. They need to make it right- assuming they are capable.
The E-brake drums are just like any rear drum brake e-brakes, there are just no wheel cylinders.
#8 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 03 July 2012 - 08:27 AM
Sometimes when taking off the rear rotors, especially in rusty areas, I have seen the lining just fall off the parking brake shoes. If that happened and they didn't fix it, it could cause that problem. Most likely though they just backed off the adjusters when removing the old rotors and didn't readjust them properly.
#9 Red92
Red92
    Subaru Fanatic!
  • 436 posts
  • Wisconsin
Posted 03 July 2012 - 01:27 PM
Seconded.
I would be a bit concerned about their competence though if they missed it the first time, and then still didn't fix it properly when you brought it back the second time. :-\
#10 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,902 posts
  • Near Cortland NY
Posted 03 July 2012 - 03:13 PM
They are probably just spinning the wheel on the lift by hand, then seeing if it's tight enough they can't.
#11 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 03 July 2012 - 03:57 PM
They are often overlooked, which is a shame as it is something that a shop can make like 19.00 off of for zero work on their part, lazy shop.
#12 ibroad
ibroad
    USMB Regular
  • PipPipPip
  • 69 posts
Posted 04 July 2012 - 09:27 AM
Yeah I'm not even going to take it back to them again.
I'm just going to leave them a negative Google review ... that will teach them.
