2001 Legacy gas filler tube goes into abyss.
12 replies to this topic
#1 BrokenSubaru
BrokenSubaru
    New User
  • PipPip
  • 12 posts
  • Wayland,MA
Posted 10 July 2012 - 01:57 PM
OK, I'm trying to track down my P0442 code problem. I've read all of the posts. I previously had a mechanic replace the purge solenoid. I pull the inner fender wall to take a look at the fuller tube and it looks pretty rusty. I tried to follow it, an it seems to go way into the abyss :mad: above the rear suspension. So where is the vent solenoid, and is changing the filler tube on a 2001 Legacy a nightmare?
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 10 July 2012 - 03:56 PM
Not a nightmare but you do need a fair amount of room under the car to maneuver. The filler tube goes under the frame then fits to a section of rubber hose just above the rear crossmember. The ring clamp there is accessible but you'll want a hose pick to get the rubber section loose from the metal tube.
With the tube loosened from the body it can be pulled out of the rubber hose and then lowered out of the wheel well.
#3 john40iowa
john40iowa
    USMB is life!
  • 218 posts
  • Ankeny
Posted 11 July 2012 - 12:18 AM
I feel your pain, had mine replaced last summer. What does not make sense to me, in a car designed for bad weather, why this problem is not addressed and remedied with new models.
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 11 July 2012 - 12:50 AM
I speculate that its not an issue in most of the world. I don't think salt is put on roads in many areas outside the US. Its just expensive and in most snow and ice areas in the rest of the world they know how to drive on the stuff without it.
Im doing one here in Colorado but its fairly rare here unless the car has seen areas east of here. For the most part they didn't rust out here.
#5 BrokenSubaru
BrokenSubaru
    New User
  • PipPip
  • 12 posts
  • Wayland,MA
Posted 11 July 2012 - 08:06 AM
My in-laws are from Maine, and they are spraying this mixture called brine on the roads before storms. It's worst than salt, it's rusting out everybody's brake lines.
#6 unibrook
unibrook
    Sube1
  • 508 posts
  • Boston
Posted 05 May 2014 - 05:54 AM
Fuel Filler Neck – CEL:  P0442
2001 Forester with 128k rust belt miles on her.
Bot new neck pipe on Ebay.  Hoses, screws, hose clamps...you will get at
AutoZone.  The new check valve
you get at Subaru dealer.  Some of the
mounting bolts might be frozen, but tap them with hammer and wood and spray
with WD40 for 15 minutes before cranking them off might help.  The hardest part for me was trying to
separate
the hoses from the corroded steel pipes and lines.  All seemed
impossible.  I suppose you could saw apart the old rusted filler
neck and get some swing room that way to twist it out of the rubber hose
connecting to the gas tank.
Edited by unibrook, 22 May 2014 - 06:28 AM.
#7 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 05 May 2014 - 07:22 AM
Last Fall my filler pipe rusted out to throw a CEL. Yea, there is a good share of road salt used in Indiana during winters. I had a buddy remove the pipe, and found a rusted mess. The weather was getting too bad to find one in a yard. He is a good welder, so he welded strips of metal over the holes on the pipe. He reinstalled the pipe, and threw away the pipe cover. The finished repair worked like a champ. No more CEL.
#8 jarl
jarl
    Subaru Fanatic!
  • 551 posts
  • Ann Arbor area
Posted 05 May 2014 - 08:03 PM
Unibrook mentioned it but let's make it more explicit: do keep in mind you are getting rid of the old filler tube! That is: if you need to destroy it to make it easier to remove, so be it.
That being said, make sure you have the right part to replace it, and that you don't destroy more than you have to :)
Edited by jarl, 05 May 2014 - 08:04 PM.
#9 unibrook
unibrook
    Sube1
  • 508 posts
  • Boston
Posted 14 May 2014 - 04:00 PM
Very good point.  The first replacement filler pipe I bot off Ebay was made by Dorman....and was not the correct part.....even though the description said it would fit.   So, before you order the new one, crawl under the car, do a visual survey, take pic, then be sure it matches when you go on line to order the new one.  I hate when frikkin aftermkt parts have erroneous descriptions......and it happens A LOT !!
#10 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 15 May 2014 - 09:44 AM
Yea, I have had the same trouble. Order or store buy after market parts that say they will fit, but won't. Nothing worse then to be in the middle of a repair project, then find out you are screwed by having a wrong part.
#11 Junkie
Junkie
    Advanced Member
  • PipPipPip
  • 65 posts
  • San Luis Obispo, CA
Posted 15 May 2014 - 10:00 AM
Brine is just another word for saltwater. It could be that they're using different salts.
I sure am glad that I live in California and not right on the coast. No rust...
#12 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,014 posts
  • East Coast
Posted 15 May 2014 - 10:42 AM
i just replaced a gas filler tube.  wasn't that bad.
the trickiest part someone just mentioned is the tube doesn't want to come out of the rubber hose.  and "pushing" on the hose means simply pushing the hose back into the vehicle cavity rather than off the neck.  i had a friend hold the neck while i broke the seal of the hose, that helped.
#13 ThosL
ThosL
    USMB Regular
  • 648 posts
  • new england
Posted 15 May 2014 - 06:38 PM
I'm OK most of the time with my gas filler issue, with older pumps the gas leaks, sometimes badly.  I just look for modern pumps, etc..
