flywheels same for ea81 & ea81T
9 replies to this topic
#1 shanonsf
shanonsf
    USMB is life!
  • 140 posts
  • san francisco, ca
Posted 29 March 2004 - 04:18 PM
hey all,
getting ready to do my clutch and was curious if the flywheels were the same from a ea81 and a ea81T??
I have ea81T on stand, thinking on having it's flywheel turned and ready for my ea81 clutch job, it be very convenient.........
thx
shanonsf
#2 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,796 posts
  • Denver, Colorado
Posted 29 March 2004 - 04:45 PM
An ea81T never came with a flywheel cuz they were all Automatics.
Which one you use depends on the trans you are going to use mostly.
#3 shanonsf
shanonsf
    USMB is life!
  • 140 posts
  • san francisco, ca
Posted 29 March 2004 - 11:30 PM
here's the deal
I have a ea81T on stand that came outta a project with a RX 5spd D/R & ctr dif & LSD. (yes, I have the tranny/lsd on ice)
Turbo motor won't be going in any time soon, nor 5spd. Turbo has a flywheel easily accessible (exposed) and was thinking of having it turned and lightend for the 4spd and later for 5spd when ready
will this work?
thx
shanon
#4 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 29 March 2004 - 11:46 PM
Depends on which flywheel you have. They could have used either one. You'll have to figure out if you have the EA81 or the EA82 flywheel. In order to fit the EA82 flywheel, the bell-housing must be ground slightly. You should be able to tell. You need to use the EA81 flywheel with the 4 speed, but you can use either one with the 5 speed. You might be able to use either one with the 4 speed, but I'm not sure on that. I've not heard of anyone putting the EA82 flywheel and clutch on the EA81 engine and tranny.
#5 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,109 posts
  • Sumner
Posted 29 March 2004 - 11:48 PM
The flywheel is more than likely for the EA82 5sp trans. You can have it lightened but you will need to verify that it came from an EA82 originally. Clutch is different.
#6 ShawnW
ShawnW
  • Administrator
  • 12,796 posts
  • Denver, Colorado
Posted 30 March 2004 - 12:33 AM
No grinding is required on the bellhousing.
#7 shanonsf
shanonsf
    USMB is life!
  • 140 posts
  • san francisco, ca
Posted 31 March 2004 - 12:05 AM
thx fellas,
the ID = 225mm (9") on turbo's flywheel, i assume that's a ea82T unit?
are the 4spd ea81s a 200mm (8") dia , that's what's in her now i expect, stock for 82 GLW?
should I just keep her stock until I do the major swap?
shanonsf
#8 ShawnW
ShawnW
  • Administrator
  • 12,796 posts
  • Denver, Colorado
Posted 31 March 2004 - 12:08 AM
The 225MM part means its a clutch of that size but it could be an 84 4wd or newer or its an ea82 flywheel.
#9 Qman
Qman
  • Moderator
  • 11,109 posts
  • Sumner
Posted 31 March 2004 - 11:08 AM
Should also note, no grinding on the automatic bellhousing. Manual bellhousings require a bit of fit and fair.
#10 MilesFox
MilesFox
    Catch this Fox!
  • 9,130 posts
  • Madison/Milwaukee, WI
Posted 31 March 2004 - 12:51 PM
..for EA81T. as far as your choice of flywheel, use the one that goes with the tranny you are using
ea82's have larger holes for the flywheel, but you can use ea81 bolts with the ea82 flywheel, as the flywheel will still center on the crank snout
