I just installed a new coil & Resistor on my 83 GL and my question is:
When the switch is placed into the start position does he coil get a full 12 volts?
Thank you
Jack
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Coil & Resistor & Question
Started by
texasjack
, Aug 02 2012 08:42 AM
2 replies to this topic
#1
Posted 02 August 2012 - 08:42 AM
#2
Posted 02 August 2012 - 10:32 AM
83s don`t have ballast resistors so there is no provision for bypassing one like on earlier cars.
Coil will see less than charging/battery voltage every time the ignition module completes the circuit w/the engine turning.
#3
Posted 04 August 2012 - 07:40 PM
You can change to the resister type coil setup on any vehicle with the advantage being the coil is designed to run via resistor at lower voltage Normally,but when bypassed in starting switch position gives increased coil output with the non resisted 12 volt feed for a stronger spark and easier starting.
That is why the factories did it and is an easy upgrade that is worth the effort.
The wiring mods are not that hard .
