Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
'92 loyale 4x4 wagon build
#101
Posted 31 October 2012 - 11:26 AM
#102
Posted 31 October 2012 - 05:37 PM
pull the vacuum line off the fuel pressure regulator and see if fuel comes out. if it does then it explains your power/starting issues. every subaru i've ever had or driven has no problem getting to 65. even fully loaded.
if its not the fpr then double check your distributor timing. and re-tension the timing belts. pretty simple.
if theres no codes then its a problem with a part of the engine that isnt monitored by the ecm.
hows the plugs? are they gaped correctly? cap and rotor, is the center button in the cap springy still? corroded? air filter? tap it on the fender and see if its full of dirt. fuel filter? no real way to check it but they are like $10, and always a good investment.
very sweet car, simple, cheap and effective, i have some what the same plan for mine, i just need the lift.
i hope you get the power issues sorted:popcorn:
#103
Posted 31 October 2012 - 09:01 PM
I know of the large air dams on the rear of the cab, I've seen plenty of those, and it probably helps.
Surely some type off flaring on your roofrack will help. Add a wedge to the front (Like a Daytona) :-p
#104
Posted 31 October 2012 - 11:19 PM
250k is barely even broken in. and i dont know of any subaru with"easy miles" lol
I had the timing reset and the belt tension checked a few weeks ago which did help some. the only code that reads is the EGR which Ive been told should have little effect. Plugs are brand new and gapped correctly as well as the cap and rotor. New Wix air filter as well. The fuel filter is supposed to be a year or so old according to some receipts that came with the car when i bought it. I have yet to check the regulator. If fuel runs out of the regulator while the vacuum line off, would that mean the regulator is bad? I've never really messed with regulators much. It doesn't have any issues starting, only getting up to speed after about 45ish. Thanks man. Hope you have a bit better platform to work with than i do :-p
As for flaring/air dams. Yes it does make a large difference (Really noticeable in 18-wheelers) those little flares which run along side of the trailer will add 1mpg (Which adds up) and I'm sure the drag is also helped.
I hope it does, I'm going to pick up some steel in the morning to get to work on it. That wedge would be an interesting addition, i wonder if anyone has tried that. Id even think about making one if i didn't have an obsession with taking this beast offroad
Does anyone know if there has been a ej20tt swap in an ea82? i found a good deal on a low mileage engine with the computer. My buddy wants my engine for his buggy so that'd be a perfect excuse for an engine swap
#105
Posted 01 November 2012 - 01:58 AM
#106
Posted 01 November 2012 - 05:02 AM
#107
Posted 01 November 2012 - 11:02 AM
#108
Posted 01 November 2012 - 05:41 PM
#109
Posted 01 November 2012 - 09:16 PM
#110
Posted 01 November 2012 - 10:03 PM
... Should just buy it anyways, could be a killer engine transplant in my s10 :-p
There is a Reason for that engine for being so Cheap: it Won't fit any LHD Subie... Nor your S10.
#111
Posted 01 November 2012 - 10:23 PM
It took some modifications to make it fit... but it worked.
You could still use the engine, just convert it to single turbo. Basically use the longblock and bolt all USDM manifolds to it with a usdm wrx wiring and computer.
#112
Posted 06 November 2012 - 11:45 PM
Idk if there was a brat or not, ill have to look around for it. If I find it ill post a link.
Might be putting new exhaust on the car soon. Made a bet with my old man and I won...of course :-p any ideas for a good muffler? Im looking for something with a nice tone and a generally small design. I'm thinking a thrush welded, they are fairly cheap, nicely toned, small design. I know a few people running this muffler and they all love them.
#113
Posted 16 December 2012 - 12:31 AM
I'm in the process of making my 2" lift. fpr the rear, I know the tabs are bent at a 45° angle. but does anybody how long they are?
#114
Posted 16 December 2012 - 09:12 AM
#115
Posted 16 December 2012 - 12:32 PM
#116
Posted 20 December 2012 - 12:17 PM
on another note, I found a 99 outback sedan real cheap with a bad headgasket. is this a common problem? how much of a b*&%$ are they to change?
#117
Posted 21 December 2012 - 10:22 PM
Pretty common in the 2.5 engines of that year.
there are some how-to threads on here somewhere. It's a pain but doesn't seem too bad. (Crossing fingers as I have yet to perform this fix) But 2 basic options.
1. Pull the motor and have plenty of space to work.
2. Don't pull the motor and swap it in the car in more cramped and awkward conditions.
You'll probably get a variety of advice on which is the easier/better way to do the swap. But either way, I wouldn't be too scared of it. Seems pretty straightforward.
#118
Posted 22 December 2012 - 03:35 PM
#119
Posted 22 December 2012 - 03:51 PM
#120
Posted 23 December 2012 - 12:12 AM
pull the motor, it doesnt add that much time, and your back will thank you. the time it takes to r and i a motor cant be much more than the extra time it takes to find things you cant see/drop/didnt know were there etc. plus youll find AND have access to all the stuff you didnt know was wrong and fix it easier
#121
Posted 23 December 2012 - 01:10 AM
Looks pretty awesome. Figure out a solution for the roof rack yet? Video/sound clips of exhaust?
Thanks a lot! For being a beater, i seem to get quite a bit of compliments
#122
Posted 23 December 2012 - 11:50 PM
#123
Posted 25 December 2012 - 12:09 AM
#124
Posted 13 January 2013 - 04:09 PM
My home made spring compressor, kinda sketchy but worked.
#125
Posted 13 January 2013 - 05:46 PM
