Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EJ25 crank wobble
#1
Posted 15 September 2012 - 04:06 PM
Then I stopped at auto zone to clear the ECU and I get on the highway, just as I get on the highway the belt for the alt, PS pump snapped so I go and check and the crank is wobbling (I have a video) The bolt was not loose at all so I'm a little baffled by this. I ended up coming directly home, again keeping the tools in the rear is a smart thing to do, I was checking voltages on the way home and I was down to 10.6 V
#2
Posted 15 September 2012 - 05:32 PM
remove the pulley and examine it for wear on the rubber and the keyway.
#3
Posted 15 September 2012 - 06:44 PM
#4
Posted 17 September 2012 - 02:28 PM
Does anyone have the part number for the woodruff key if I need to replace it?
#5
Posted 17 September 2012 - 03:57 PM
I just ended up cutting the AC belt since it was the fastest and I'm going to replace both belts anyways.
The key is worn, anyone have a part number?
Edited by 1-3-2-4, 17 September 2012 - 04:04 PM.
#6
Posted 17 September 2012 - 04:10 PM
!wobbing! look like nut, eh?
you need new crankshaft pully and
maybe new crankshaft...look like damage 'key'. but i dont want said it...
go to subaru dealership..it's alot money and it's not fun for pay.
P.S. go to junkyard...way better for it.
Edited by Suba_GL_87, 17 September 2012 - 04:22 PM.
#7
Posted 17 September 2012 - 04:11 PM
#8
Posted 17 September 2012 - 04:31 PM
that's pretty sick.
im end of thread.
Uhmm no I don't.. I need a new crank pulley and a new woodruff key.
#9
Posted 17 September 2012 - 04:45 PM
but you need a new pulley and i would replace the key.
and i would remove the sprocket and examine it and the rest of the key way. i know it is more work but at least then you will know it is all good.
i would then put it back together with the sprocket and pullet lined up correctly and torque the crap out of it.
as shown by the damage to your pulley, the key is not designed to hold the pulley (or the sprocket) in place, the key only lines up the pulley and sprocket. the bolt holds it in place. and the damage to the crank keyway, if any, is in the loosening direction, not the tightening direction. so the new key will do it's job as you torque it.
since you will be torquing the crap out of it you might consider a new bolt.
Edited by johnceggleston, 17 September 2012 - 04:51 PM.
#10
Posted 17 September 2012 - 06:08 PM
For google search purposes since I never found anything searching google for the key part number it's 804505060.
Woodruff key part number 804505060.
Ok I think I have that covered now
#11
Posted 17 September 2012 - 06:47 PM
Yeah I think something the last owner did caused this because I've never seen it like that before.. Might be rather hard to get off the crank sprocket, I should of cleaned it up with a scotch pad, I already have the part number for the key..
#12
Posted 18 September 2012 - 01:56 PM
#13
Posted 19 September 2012 - 05:38 AM
lol i ran over my belt today when driving home, it popped pretty far back
#14
Posted 20 September 2012 - 08:20 PM
and both new center TB cover and Left side TB cover and new gaskets for the TB cover.
I wonder.. I don't have my lightweight pulley here yet but I think looking at the backside of the pulley the key notch should run from the front to the rear of the pulley right? In that case then it must of been from the last owner not doing the crank pulley right I wonder why I never noticed it when I did the HG last year.. I'm guessing the Torque of the motor was enough to chip enough of the key so it caused the up/down movement but the bolt still being at 150 ft/lb kept the pulley from free spinning.
At least that's my take on that.
yep just looked at some others online
Edited by 1-3-2-4, 20 September 2012 - 08:28 PM.
#15
Posted 02 October 2012 - 10:44 PM
given how the key is not really that bad I could get away with it but I want to take the crank sprocket off to clean it with a scotch brite pad.
#16
Posted 03 October 2012 - 08:44 AM
Had to be from the last owner but when the car ran low of fuel the rocking back and forth and the torque on the key must of smoothed out the whole keyway (How that happened who knows)
but I got as close as I could and it does not seem that bad, at least I caught it early but it's been almost a week and I'm still waiting for the new parts.
If I don't hear anything today I'm going to email them.. I don't think they should charge the card if it's not really in stock. I mean I think what Dan Perkins is cool and all but at least my other dealer in Norwalk will order the parts for you and you pay when it really comes in.
#17
Posted 03 October 2012 - 09:29 AM
So I still have to wait :-/
#18
Posted 03 October 2012 - 09:35 AM
#19
Posted 03 October 2012 - 09:48 AM
have fixed many with thiss problem got realy good at it in car pully key reluctor and time
It's going to be a pain to get the spocket off I did lube it with oil when I put it back on a year ago but then it was hard to put on, Not sure why I did not scotch brite it for some reason :-/
I will have to see if I can't get it off with a screwdriver then I will have to use jaw pullers.
#20
Posted 03 October 2012 - 09:59 AM
#21
Posted 03 October 2012 - 11:48 PM
#22
Posted 04 October 2012 - 03:45 AM
I think I'm going to get another sprocket to go along with it as well when I remove it.
I've got those. PM if you need one.
#23
Posted 04 October 2012 - 08:25 AM
#24
Posted 04 October 2012 - 10:35 AM
#25
Posted 04 October 2012 - 11:58 AM
