2005 Outback XT Cruise Control
9 replies to this topic
#1 outbacknover
outbacknover
    New User
  • Pip
  • 6 posts
  • St. Louis
Posted 18 September 2012 - 06:27 PM
My cruise control works but when engaged it surges and does not capture the set speed.
Engaged and going down a hill it really goes crazy and can't find that happy medium.
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,282 posts
  • Houston, Tx
Posted 19 September 2012 - 12:27 PM
Do you have a check engine light on by chance?
Those cars are drive by wire and have an electronic throttle. How does the car drive/behave when just driving normally without the cruise on?
#3 brus brother
brus brother
    Subaru Master
  • 1,805 posts
  • Connecticut
Posted 19 September 2012 - 06:25 PM
I recall there was tsb concerning cruise lunging in this year.
#4 outbacknover
outbacknover
    New User
  • Pip
  • 6 posts
  • St. Louis
Posted 20 September 2012 - 04:47 PM
No check engine light and no lunging without the cruise on.
Brus... Any chance you have a link to the TSB?
#5 brus brother
brus brother
    Subaru Master
  • 1,805 posts
  • Connecticut
Posted 20 September 2012 - 07:40 PM
googling around found this little tidbit:
http://www.cargurus....t17299_ds469549
I know there are issues with hills and 2005's cruise control.
See here:
http://legacygt.com/...25.html?t=10725
I don't have the tsb but google 2005 Subaru cruise control problem and you will find some fun reading. Ignore the threads that include issues of check engine light as their problem is unrelated to yours. Cruise stops working if there is a CEL. Not your problem.
#6 outbacknover
outbacknover
    New User
  • Pip
  • 6 posts
  • St. Louis
Posted 21 September 2012 - 10:35 PM
Thanks, BB. Emailing the dealer service manager.
#7 outbacknover
outbacknover
    New User
  • Pip
  • 6 posts
  • St. Louis
Posted 09 October 2012 - 08:18 PM
Yeah, so dealer service manager gave me the dealer, "Bring it in and we'll take a look at it."
So, I'm not ready to spend the $ for a dealer opinion.
Any other ideas?
I did replace the rear wheel hubs and the left front hub recently, O'Reilly's says they were OEM.
#8 wtdash
wtdash
    Subaru Nut
  • 728 posts
  • N. ID
Posted 09 October 2012 - 10:21 PM
I'd only suspect the replaced parts if you have a CEL, ABS or other light on.
You searched/asked over on the SubaruOutback.org site?
I just read thru the LGT thread offered up by Brus and it stated that some people had success w/the ECU reflash.
You could fudge and state your CC is stopping when asking the dealer for a reflash, which seems to be the more common or @ least more readily fixed by the reflash.
If you don't get anywhere asking specifically for this w/the local service mgr, I'd put in a call/email to SoA and 'nicely' push for getting the reflash....it may cost you $85 or if you're regular customer (maintenance or otherwise) they may split the cost w/you.
I'd also be calling other dealers (gotta be more than 1 in St. Louis??).
What trans? If yours is the MT, I'd replace your Neutral sensor, too, as noted.
Also, have you tried to reset your ECU? Read on here/line how to do that....if you have an alarm or security code on your stereo/head unit, you'll want to get info on resetting those b4 'pulling the plug'.
After the reset, see if the cruise is any better initially.
GL,
TD
#9 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,780 posts
  • Denver, Colorado
Posted 10 October 2012 - 02:12 AM
My moms 2006 Outback does this and it started after I replaced all of her wheel bearings. I found a sensor I had cracked and replaced that and had the reflash done. It got a little better but still haven't gotten to the bottom of it.
#10 outbacknover
outbacknover
    New User
  • Pip
  • 6 posts
  • St. Louis
Posted 11 November 2012 - 10:16 PM
Alright, alright...
Replaced the left front hub yesterday, again. I missed my cruise control.
Lo and behold replacing the O'Reilly's OEM (made in China) with a factory (made in the USA) hub solved the lunging issue.:clap:
I went to O'Reilly's with hub in hand and explained and accepted it as a warranty return.
I inspected the hubs prior to installing, nothing really to note. The Chinese hub does have a heavier casting, its thicker and conically shaped adjacent to the hub. The factory hub, definitely less girth and more symmetrical adjacent to the hub.
