92 Legacy Clutch Sticks
4 replies to this topic
#1 SubieTrav
SubieTrav
    USMB Regular
  • 140 posts
  • Denver
Posted 05 October 2012 - 02:39 PM
My 92 Legacy wagon has an issue with the clutch pedal sticking to the floor when the weather is cold. After driving it a couple of miles it works fine. The clutch has about 7K miles on it. It has always given me problems since having it done. I keep adjusting the cable and it works for a while and then acts up again. It hasn't been as bad after I disconnected the hill holder.
#2 wtdash
wtdash
    Subaru Nut
  • 1,564 posts
  • N. ID
Posted 09 October 2012 - 06:10 PM
Huh...no responses....:confused:
My .02 is the cable is worn out and is stretched...that's why adjusting helps.
A new cable isn't that expensive or hard to replace, IIRC. I put in a new one when I did my AT>>5-speed swap on my '90 Legacy.
GL,
TD
#3 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 09 October 2012 - 06:39 PM
Is it rubbing our routed the wrong way? The old 80's Subaru cars you could route the cable on the steering linkage and have it rub thru very quickly. I think the cable or the hill holder are suspect here.
#4 SubieTrav
SubieTrav
    USMB Regular
  • 140 posts
  • Denver
Posted 10 October 2012 - 08:45 AM
I'm going to replace the clutch cable when I get a chance, there is some squeeking noise when I step on the clutch pedal. It would be nice to start in 1st gear and not feel like I'm popping the clutch.
#5 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 10 October 2012 - 05:40 PM
Clutch cable first. Its cheap and.takes ten minutes to.change. if that dont.fix.it check the throwout bearing
