Steering feels stiff
9 replies to this topic
#1 Speedwagon
Speedwagon
    Eat, Live, Breath Subaru
  • 328 posts
  • Denver, CO
Posted 12 October 2012 - 11:19 AM
'98 Legacy GT. The steering feels stiff to me lately. It seems like it "sticks" wherever it's at(as in, it resists turning if straight, or resists returning to center if turned). Kind of hard to pinpoint, but just doesn't feel right to me. PS pump has fluid(at proper level).
Any thoughts on this?
#2 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 4,774 posts
  • Roatán, Honduras.
Posted 12 October 2012 - 11:37 AM
It sounds to me like a Worn and / or Loose Belt Slipping... They doesn't make noise at the PS pulley, so I Kindly suggest you to check the Belts.
Kind Regards.
#3 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,796 posts
  • Denver, Colorado
Posted 12 October 2012 - 03:50 PM
Check the rubber at the steering u joint.
#4 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 5,603 posts
  • Virginia
Posted 12 October 2012 - 04:22 PM
try spraying somre lubricant on the steering u joint. it it is old and stiff it may be your problem. the spray will only be a short term fix, but at least you will know what the problem is. you can swap in any steering u-joint 95 - 99 that is NOT and outback. outback is different.
an oil can with 30wt oil may do the job, if you can reach it, and it may last longer.
#5 Speedwagon
Speedwagon
  • 328 posts
  • Denver, CO
Posted 12 October 2012 - 09:09 PM
When I went looking for a u-joint to use in the Brat for a lift, I saw no difference in a 95-99 Legacy and Outback. They appeared identical to me.
And thanks, I'll check the u-joint. Belt is good, it's not that old, and no signs of it slipping.
#6 djmark7
djmark7
    USMB is life!
  • 180 posts
  • NW New Jersey
Posted 13 October 2012 - 02:33 AM
use pb blaster, works GREAT
#7 uniberp
uniberp
    mpergielwalkermi
  • 593 posts
  • Walker, MI
Posted 13 October 2012 - 06:55 AM
Ball joint(s) froze?
#8 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 3,752 posts
  • Mason
Posted 13 October 2012 - 12:35 PM
The outback steering coupler is longer between the two u-joints because they have spacers between the body and the crossmembers on the outbacks.
Last one I bought was $75 new from the dealer, so they're not too expensive to replace. Just don't spin the steering wheel while you have the coupler removed, the clock spring connector for the airbag will break and that's much more expensive to fix.
#9 Speedwagon
Speedwagon
  • 328 posts
  • Denver, CO
Posted 27 October 2012 - 10:58 AM
With the recent cold weather blast here in Denver, I've noticed the issue a bit more. And it feels like a U-joint, in that it is stiff, then turns easier, then gets stiff again. Haven't poked my head down there yet, but I may just go grab another at the junkyard for cheap, and swap it out.
#10 Speedwagon
Speedwagon
  • 328 posts
  • Denver, CO
Posted 18 November 2012 - 05:57 PM
Very much the ujoint. I got it off today, and the one part of the upper joint was too seized to move by hand. Put in the one I got from the junkyard, and my steering is much better now. It returns to center again.
