Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Disabling wipers-with-washer button
#1
Posted 22 October 2012 - 12:07 PM
To me this is the most monumentally stupid feature conceivable, at least for those of us who have winter!
I am sick of the wipers dragging across a bone-dry dirty windshield before the squirter starts squirting, and don't even get me going on the agony of the line being frozen or the reservoir empty.
#2
Posted 22 October 2012 - 01:10 PM
Has anyone set it up so the washer button does not turn on the wipers?
not much snow here, but idoes kinda "offend my sense of order" that first wipe-and-a-half or so are dry.
interesting
might just require pulling a wire or 2 off of a timer or relay somewhere.
or, alternatively, wire in a separate push button just to squirt washer fluid.
Edited by 1 Lucky Texan, 22 October 2012 - 02:42 PM.
#3
Posted 22 October 2012 - 11:09 PM
That should work.alternatively, wire in a separate push button just to squirt washer fluid.
The wiring diagram for my 2002 Forester shows that the wiring connections for the washer motor are mostly inside the combination switch.
The washer switch feeds two pairs of wires: One pair connects internally to the Intermittent Switch module (this is what triggers the wipers); the other pair feeds externally to the washer motor.
One could disconnect this external pair of wires from the combination meter, and then reconnect them to a new push-button. The P-B would then energize the washer, but not the wipers.
#4
Posted 23 October 2012 - 08:29 AM
http://offroadingsub...aythenwipe.html
There's a resistor you pull, and it disconnects the washer button from the intermittent wiper control.
#5
Posted 23 October 2012 - 08:45 AM
I was willing to bet if I pulled the switch apart I could find the right circuit-board trace to cut (taking apart the un-dissassembleable is a talent of mine), someone pointed me to this:
great find!
#6
Posted 23 October 2012 - 09:42 AM
#7
Posted 23 October 2012 - 11:19 AM
I hate to say, I can't wait to do this...
#8
Posted 23 October 2012 - 11:43 AM
if you pull this part out, see if you can trace the lands from that location.
I'm reluctant to do this to my wife's car. she's VERY sensitive to any alterations to it. Always asking why and crap like that lol!
#9
Posted 23 October 2012 - 01:24 PM
#10
Posted 23 October 2012 - 01:28 PM
#11
Posted 23 October 2012 - 01:47 PM
I don't see the spot you mean.
start at the top, just as you come down, past the very first solder pad, there are 2 large thru-hole connections, vertical to each other, which are kinda dirty/smudgey looking. Look to the left of the lower one. There's an unused surface-mount position. I was just wondering what its purpose could be.
Edited by 1 Lucky Texan, 23 October 2012 - 01:49 PM.
#12
Posted 23 October 2012 - 06:43 PM
Maybe this same module is inside the rear wiper controller and has a few positions populated differently.
I can try to pin out mine if I get to messing with it.
#13
Posted 24 October 2012 - 09:52 AM
Well, crap, mine is different.
Looks like that one had the wiper on the left side of the column, mine is on the right, as my board looks a little like a mirror-image of that one but the layout is different.
I think I have the correct resistor isolated, stalk connector looks different.
Edited by CNY_Dave, 24 October 2012 - 09:57 AM.
#14
Posted 24 October 2012 - 10:39 AM
Pic of bottom of board, and of the track I cut that goes to the resistor.
#15
Posted 24 October 2012 - 11:00 AM
Success!
good job buddy!
thanx for posting
#16
Posted 30 November 2012 - 05:05 PM
#17
Posted 30 November 2012 - 06:41 PM
The track you cut. Is that the one with the light colored line in it?
Yes, the track that leaves the upper-right corner of the resistor that says "183" then goes under the one that says "133", you could also remove the resistor, but cutting the track is easier, I think.
http://www.ultimates...69&d=1351093134
#18
Posted 30 November 2012 - 11:28 PM
cutting the trace is good technique. It's reversible. scrape the solder mask off the trace on both sides of the cut and bridge over with solder - or a strand of wire (like 28 gauge wire-wrap wire) and solder over the gap.
