EA82 Lowering!
9 replies to this topic
#1 KristjanJohann
KristjanJohann
    USMB Regular
  • PipPipPip
  • 110 posts
  • Reykjavik, Iceland
Posted 24 October 2012 - 02:35 AM
Hi, I've had my GL10 EA82 sedan lowered for some time now on Honda Civic Sleeves and I'm sick of the bouncing. I really want to get some nice coilovers to fit to my stock setup but I would be willing to mod the tops if necessary.
From what I've read and heard two things can be used...
- What SuberDave did, modified a '05 Legacy coiloverkit to his GL. (Correct me if I'm wrong)
- Mazda MX-5 Coiloverkit.
I found cheap Raceland ones, I know it's not the best product but hey, gotta start somewhere ;)
Here is a link to those coilovers:
http://www.racelandu...-coilovers.html
Seems like I could mod the top on two in the rear and in front cut the bottom off and stick the strut into the stock hub.
Any advice and thought are greatly appreciated!
- Kristjan
Edited by KristjanJohann, 24 October 2012 - 02:38 AM.
#2 tractor pole
tractor pole
    [catch phrase here]
  • 552 posts
  • Monroe, WA
Posted 24 October 2012 - 02:56 AM
Suberdave's GL has a five lug swap, if you were willing to go that route the fronts could be an EJ front coilover setup (not 100% sure of year range) and MX-5(Miata) rears from what I understand they bolt right in and allow for lower than you can get with sleeves on stock EA rear struts.
as far as if you could cut the bottom of the front MX-5 coil-overs and fit them into the front knuckles, you might get lucky... but you would probably have to get them in hand to see if they fit.
Ben
#3 ABawm 88 GL
ABawm 88 GL
    USMB Regular
  • PipPipPip
  • 83 posts
  • Westside Olympia
Posted 24 October 2012 - 03:43 AM
I'm pretty sure if you do those miata ones you will need to do some serious fab work compared to if you just shop around a little.
#4 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 24 October 2012 - 06:05 AM
Numbchux has miata suspension on his wagon... Ive been trying to get some details on it since Im about to go 5 lug and lower about 2.5"
#5 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,188 posts
  • WA
Posted 24 October 2012 - 08:59 AM
Suberdave (and I) used 05 Legacy on the rear and 02 WRX on the fronts. This is if you have done the 5 lug swap.
The WRX stuff will bolt right up if you have a 87.5 MY and up. You need to do some work to fit the 05 Legacy bottoms . Remove the capture nut then drill the hole bigger so the bolt will fit thru. The top hat needs to bolt to the EA82 mount, so the bushing cup needs to be removed.
I'm using BC Racing adjustable coilovers which are a little cheaper than some of the other major brands out there and are just as good.
Edited by Turbone, 24 October 2012 - 09:03 AM.
#6 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 24 October 2012 - 11:57 AM
Curse having an 1986... Do I even need to ask what the mods are for one of these or is it more :Flame: haha
#7 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,120 posts
  • Oregon City
Posted 24 October 2012 - 02:56 PM
I'm currently working on the rear setup but '08 and newer Impreza chassis use a similar multilink rear suspension like the Legacys since 2000. I have found that the lower hole in the factory WRX shock for the rear is the same size as the EA82 bolt so no modification needed there. I'm still waiting for a couple bits to arrive before I assemble them and install them into the XT6:brow:
#8 SmashedGlass
SmashedGlass
    Eat, Live, Breath Subaru
  • 669 posts
  • From CO, stuck in FL
Posted 24 October 2012 - 03:53 PM
What is it that causes the bouncing, the crappy Civic rated springs that come with the kits, or the lack of travel in the strut cartridges?
If it's the springs, Ground Control sells coilsprings in different lengths, diameters, and rates.
#9 KristjanJohann
KristjanJohann
    USMB Regular
  • PipPipPip
  • 110 posts
Posted 28 October 2012 - 07:43 PM
I'm planning on keeping my stock wheelhubs, I have 3 sets of redrilled 6lug rims with 195/45R15 tires mounted ;)
Pic of one of the rims inside my Mazda 626 '81
Posted Image
Does anyone have any pictures of their setup? With or without the 5lug swap.
Edited by KristjanJohann, 28 October 2012 - 07:58 PM.
#10 AWD J3wman
AWD J3wman
    USMB is life!
  • 175 posts
  • Richfield, MN
Posted 14 October 2013 - 12:57 PM
Its the super stiff spring rates on those EBay kits, if you want a good set of coilover sleeves from a civic that will fit, id recommend Ground Control. I had them on my Civic before i got Function Form Type 2s
