lmdew Posted April 3, 2004 Share Posted April 3, 2004 I've got server inner tire wear on the rear of a 93 Legacy wagon. We did swap the complete drive line a and suspension from a 92 wagon, but as far as I know 90-94 are the same. No camber adjustmets, I believe? What's the fix? Thanks Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted April 4, 2004 Share Posted April 4, 2004 you can move things a little bit when loosening the strut bolts..... They do make aftermarket camber bolts you can add which will give you a little adjustability. Quote Link to comment Share on other sites More sharing options...
lmdew Posted April 5, 2004 Author Share Posted April 5, 2004 Thanks for the info. I'm going to loosen both sides and pull them together with a strap and tighten things up. Quote Link to comment Share on other sites More sharing options...
