Fuel injectors
5 replies to this topic
#1 Reason01
Reason01
    USMB is life!
  • 126 posts
  • USA
Posted 03 April 2004 - 02:36 PM
How many cc's do stock fuel injectors run on a stock 97 Legacy 2.5 GT? Can I put in STi injectors? With out any modding?
#2 Storm
Storm
    USMB is life!
  • 143 posts
  • NEOhio
Posted 08 April 2004 - 08:39 AM
Stock EJ25 injectors should be 280cc/min. The STi injectors are (I believe) over 500cc/min. I suspect that you'll need to add a fuel controller to tame those injectors. Also, the 97's are sidefeed where the STi are topfeed (iirc) so matching fuel rails will be needed as well.
#3 Reason01
Reason01
    USMB is life!
  • 126 posts
  • USA
Posted 08 April 2004 - 09:06 AM
So what would be the most ideal upgrade to what I have?
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 08 April 2004 - 05:55 PM
Unless you have added a turbo kit, there is no need to upgrade your injectors.
The only thing you could do to them is have them balanced & blue printed, which equals out the flow rate on each and improves spray pattern.
#5 Reason01
Reason01
    USMB is life!
  • 126 posts
  • USA
Posted 09 April 2004 - 01:39 AM
Where would I get this done?
#6 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 12 April 2004 - 08:01 AM
www.rceng.com
