wrxsubaru Posted April 5, 2004 Share Posted April 5, 2004 What is the top dead center mark on the crank pullie? And which mark are you spose to use on the block? Quote Link to comment Share on other sites More sharing options...
wrxsubaru Posted April 5, 2004 Author Share Posted April 5, 2004 How are you spose to take off the crank pullie, i left it in gear ( manule, and it makes the car move around if i try to losen that way. Quote Link to comment Share on other sites More sharing options...
robm Posted April 5, 2004 Share Posted April 5, 2004 Put the hand brake on as hard as you can, or get someone to plant their foot on the brakes. Then get a big long pipe on the breaker bar, and away you go! Quote Link to comment Share on other sites More sharing options...
wrxsubaru Posted April 5, 2004 Author Share Posted April 5, 2004 Is there a top dead center mark tho? Quote Link to comment Share on other sites More sharing options...
theotherskip Posted April 5, 2004 Share Posted April 5, 2004 Put the hand brake on as hard as you can, or get someone to plant their foot on the brakes. Then get a big long pipe on the breaker bar, and away you go! put it in 5th. if you put it in 1st, it is the easiest for the engine to turn the wheels. you want to make it the hardest for the engine to turn the wheels... i had to use a 24" 1/2 drive breaker bar with a 24" section of black iron pipe over the handle. take it slow and it will go. Quote Link to comment Share on other sites More sharing options...
