Electric fuel pump????
7 replies to this topic
#1 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 05 April 2004 - 08:09 PM
I put the Carter fuel pump on today, it fired up and runs good, I did have to put on a regulator as it was running 5psi. Now the weird part. I wired it in to the existing Pump harnes, when I turn on the turn signel you can hear the pump draw down then back and then down with every blink. Do you suppose the new pump requires that much more power to run or what????? Please try and remember that I am an electrical 3rd grader so keep explanations simple with lots of detail:rolleyes: . I'm also thinking that my after market fans maybe doing the same thing, I just ran them to the existing wireing also. Thanks for any and all help. Tim
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 05 April 2004 - 08:12 PM
Tim,
which vehicle? I'm thinking of giving a seminar at the midwest meet on all the things electrical I've learned along the way :)
I'll have a aftermarket pump on, as well as some other goodies :)
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,295 posts
  • Portland
Posted 05 April 2004 - 08:18 PM
Sounds like you could use a bigger alternator.
#4 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 05 April 2004 - 08:50 PM
I'm running a 90 amp XT6 alt on this thing. Sounds like a great idea Mick, I know I can use all the electrical help I can get. Tim
#5 Partsman
Partsman
    Eat, Live, Breath Subaru
  • 262 posts
  • sunny Eugene, OR
Posted 05 April 2004 - 09:38 PM
Probably only happens at idle, right? I know that my electrical system pulses with my signals at idle (headlights, voltmeter). Our alternators don't put out much if anything at idle - need a certain rpm to excite, I think. Unless you spend an inordinate amount of time at idle, should be no worries (unless it's happening at higher RPM's, then you've got a problem).
#6 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 06 April 2004 - 12:10 AM
If you don't have a digital voltmeter already Tim you should think about getting one. They are real handy to have around for a lot of things and you can get one for around $30 dollars. Electrons are fun to chase once you understand them a little.
With a meter you can check your battery voltage and the alternator output. You may not be getting the full output of the alternator to the battery due to a bad connection and this would cause a voltage drop to the battery. You may just have a loose fanbelt also. Then again, this may just be a normal situation but it sounds to me the battery is a little low on charge.
#7 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 06 April 2004 - 12:41 AM
check your grounds and wiring and make sure that the correct bulbs are installed
#8 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 06 April 2004 - 07:08 AM
my 50 gpm/90psi efi pump, doesnt do that, and i got the stock alternator. prolly a dumb question, but do you have a small battery or something? got a gauge on that thing, to check if pressure is droping?
