It is a 4wd 3AT 92 loyale
ok, I cleaned and honed the govenor stuff, so it is not that, it slides "like butter" as the usrm says
this is what happens:
it shudders going into second
if you put more than normal stress on the transmission when in first, like going up a hill, it starts to slip
going into third is perfect, no problem there.
do you guys know what is going on now?
-AK.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
another loyale tranny problem (yeah, I know)
Started by
AKIRA
, Apr 06 2004 06:53 PM
8 replies to this topic
#1
Posted 06 April 2004 - 06:53 PM
#2
Posted 06 April 2004 - 08:32 PM
the more i read, the happier i am that my 92 loyale has the 5 speed manual with pushbutton 4wd. good luck with yours though
#3
Posted 06 April 2004 - 08:40 PM
i have no problems with mine , turbo full time 4wd a/t 85,000 mi gl-10 , also 2wd spfi a/t sedan 76,000mi
#4
Posted 06 April 2004 - 10:32 PM
this 92 loyale had its tranny fail around 150K miles.
Not sure why, the last owner may have never checked the tranny fluid, and it could have lost it all.
#5
Posted 07 April 2004 - 10:24 AM
it has 230,000 miles.
could I get some serious answers?, not to be rude or anything but I want to fix this.
#6
Posted 07 April 2004 - 10:56 AM
It sounds like you have a real tranny problem (not the easy fix type like the governor), you could try a filter/fluid change and maybe add one of the “trans fix” snake oils. I asked around and was told the Lucas stuff was the best, I had good luck with it in a K-car 904 auto (worst AT ever made), though I think the filter change did the most good. Rebuilding your tranny will be expensive, it may be time to find a good used one.
Gary
Gary
#7
Posted 07 April 2004 - 10:39 PM
HOOPED!
sounds like the clutch packs are shot,probably from poor oil change intervals!!
too bad...
too bad...
#8
Posted 08 April 2004 - 01:19 PM
what are the clutch packs? (they ingage the different planetary things right?) are they some kind of big plastic washer? because I found half of a plastic washer (about 3'' in diameter) in the fluid pan and i have been trying to find out what it is.
other than that it sounds like a new tranny is in order
-AK
-AK
#9
Posted 08 April 2004 - 05:01 PM
I have a 94 Loyale 4x4 with the 3at also. Fortuantly it has absolutly no problems shifting. Very strong shift points.
The original owner took great care of this car, and only has 92k miles on her now.
Sounds like your going to be needing a rebuild soon, bands are probably all stretched.
