Obx LSD fit in a d/r trans?
5 replies to this topic
#1 bluto5
bluto5
    USMB Regular
  • PipPipPip
  • 102 posts
  • Kankakee, IL
Posted 25 October 2012 - 09:27 AM
Hello all.
I saw Numbchux LSD fitment issues in his thread and was wondering if the Obx front LSD had been fitted to a d/r trans(Rx specifically).
I'm getting close to picking one up and have a single range trans if need be. I'd hate to find out the hard way that it won't fit tho!
Thanks, Sam
#2 Numbchux
Numbchux
    EJ conversion addict
  • 6,811 posts
  • Saginaw, MN
Posted 25 October 2012 - 11:06 AM
It should be fine in an RX trans, as the stock low range gearset in that is a 1.19:1, which is much smaller. My Carbonetic front diff has pretty good clearance from the 1.19 gearset, it's the 1.59:1 low range swap that's causing the problem for me.
#3 Crazyeights
Crazyeights
    Crazyeights
  • 1,462 posts
  • Pacific Northwest
Posted 25 October 2012 - 06:03 PM
I have an RX trans with XT6 3.9 ring and pinion installed along with 23 spline stubs (from a S/R 5spd) behind an EJ22. So far several thousand trouble free miles. I would like to open it one more time for the 1.59 swap as soon as I find a donor trans.
Numbchux - I am following your other thread, I hope you find a resolution. Good Luck!
#4 el_freddo
el_freddo
    Eat, Live, Breath Subaru
  • 694 posts
  • Lancefield, Vic, Aust.
Posted 29 October 2012 - 05:04 AM
Yeah the 1.59:1 low range will have an issue clearing the OBX diff - you'll have to shave some of the diff housing off the side opposite the ring gear side (hope this makes sense).
This has been done in a mate's liberty with a H6 powering the EA internals with the 1.59:1 low range and the OBX front LSD. It's going well too. And this is what's being done with my gearbox too. I SO can't wait to have this box in Ruby Scoo!
I believe this has been done in other gearboxes over here but I can't be sure about that and I've not been around them to say how they're going. But if this setup is holding up to the H6 I don't see why it would be an issue - so long as you don't abuse it, just like any gearbox.
Cheers
Bennie ;)
#5 mcgarvey2001
mcgarvey2001
    New User
  • PipPipPip
  • 42 posts
  • Kalispell
Posted 21 December 2012 - 03:34 PM
Your shaving to thin the flange, yes? How much do you need to shave?
#6 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,099 posts
  • NH
Posted 28 December 2012 - 10:49 AM
No, the flange side is fine, it is the shoulder of the diff case on the end opposite the flange that is running into the gears.
