Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
How can you "check" the bottom end?
#1
Posted 25 October 2012 - 11:08 AM
#2
Posted 25 October 2012 - 11:42 AM
If they aren't making noise, they are good for a good number more miles, though.
If you are chasing low oil pressure that's likely something else- loose bolts on the oil pump, pickup that is cracked, or worn out main bearings.
#3
Posted 25 October 2012 - 12:37 PM
The bearings are totally inaccessible without a complete tear down.
#4
Posted 25 October 2012 - 12:49 PM
Can't access them without splitting the block, I think.
Thanks. IMO, "noise" is relative on these engines. My '08 with 65k is not quiet, but it has no tick, slap, or tap.
Me, I am now skeptical about this so-called "piston slap" noise. Funny how it got worse just before it turned into full-blown rod-knock. This one in the 99 is pending. After a normal commute, it taps every time around. One piston or one rod? My guess is a rod.
Oil pressure is fine, AFAIK, although it is burning oil 1qt per tank, which I hate.
BTW The solution of "knurling" pistons seems 'way iffy to me, with a built-in life expectancy.
#5
Posted 25 October 2012 - 01:59 PM
#6
Is there a way to check/change rod bearings without splitting the cases?
One advantage to changing your own oil and filter. Take a close look at the oil that is drained. If the rod bearings are going, you'll see the flakes in the drain pan.
Doug
#7
Posted 25 October 2012 - 02:46 PM
Well, when the rod bearings get loose enough the connecting rod big-end hits the block and knocks out a chunk, so at least then you know what it was!
#8
Posted 26 October 2012 - 12:00 PM
Doesn't seem like piston slap.
Piston slap ussually is bad when cold, then goes away when the piston warms up and expands.
Are you sure it's not valve noise? That is a solid rocker setup. Needs adjusted every 50k or so.
