phase1/phase2 timing belt swap.
6 replies to this topic
#1 987687
987687
    Rally Suby!
  • 4,257 posts
  • Northern Maine
Posted 25 October 2012 - 07:09 PM
Can I use a phase1 2.2 timing belt kit for a phase2 sohc 2.5?
#2 capn_r
capn_r
    Pseudo Soob Noob
  • 363 posts
  • Morton WA
Posted 25 October 2012 - 07:14 PM
Phase 1 has 211 teeth on the belt. Phase 2 has 223.
#3 987687
987687
    Rally Suby!
  • 4,257 posts
  • Northern Maine
Posted 25 October 2012 - 07:21 PM
Damn, thanks for the info. I'll add that to my list. I assume all the idlers can be used though, right? Cam and crank seals the same?
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 25 October 2012 - 10:57 PM
Tensioner is different, idlers are mostly the same and usually interchangable. Water pump and cam seals are the same. Crank seal same.
#5 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,760 posts
  • East Coast
Posted 26 October 2012 - 07:42 AM
yes if you swap the Phase I 2.2 heads onto the Phase 2 block. but while i've done Phase I and Phase II swaps like that you need to proceed carefully due to clearance issues.
but normally - no, like capnr mentioned the belts are different.
you can use the Phase I tensioner on the Phase 2 block if you get the bracket that the tensioner bolts to - those are just attached to the block via a couple bolts. swap bracket and you can swap tensioner.
#6 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Posted 26 October 2012 - 08:20 AM
I have a few of these "kits" PM me if interested. I prefer the old style more reliable tensioner myself.
#7 987687
987687
    Rally Suby!
  • 4,257 posts
  • Northern Maine
Posted 26 October 2012 - 01:35 PM
Oh you can bolt on the old tensioner bracket? I was wondering about that. I may go that route.
Not putting phase1 heads on, because this is a phase2 car. I just want it to work. Heh.
