sario Posted November 12, 2012 Share Posted November 12, 2012 Does anyone have the part number, or the right name, for the valve cover breather gaskets? I'm having trouble finding the gaskets in some of the OEM online catalogs. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 12, 2012 Share Posted November 12, 2012 might want to clarify which engine. Subaru has most EJ stuff online on their own opposed forces site, have you tried there? Skip's headgasket repair page is easily found on google and has all the part numbers...assuming it's an EJ25 and the same year as his. Quote Link to comment Share on other sites More sharing options...
sario Posted November 12, 2012 Author Share Posted November 12, 2012 might want to clarify which engine. Subaru has most EJ stuff online on their own opposed forces site, have you tried there? Skip's headgasket repair page is easily found on google and has all the part numbers...assuming it's an EJ25 and the same year as his. OOOPPPS that would be helpfull. 97 DOHC 2.5, out of legacy outback. I'll go check those sites out. Quote Link to comment Share on other sites More sharing options...
sario Posted November 12, 2012 Author Share Posted November 12, 2012 Well now i feel dumb. I took less than two minutes to find the part on Opposed forces. It's called a "Gasket-oil separator cover." The part number is 11832AA021 and 11832AA022. Thanks grossgary. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 12, 2012 Share Posted November 12, 2012 obscure parts are often tricky, glad you figured it out. Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 13, 2012 Share Posted November 13, 2012 iirc you can make that gasket out of fiber gasket material if the old one was made out of similar material. If not "The Right Stuff" can prolly be used. Might save you some time and $ Quote Link to comment Share on other sites More sharing options...
